Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I'm trying to convert my GE Profile JGB908SEKbSS 30" range back to natural gasI'm trying to convert my GE Profile JGB908SEKbSS 30" range back to natural gas
The manual doesn't list instructions as to which orifices to use, and that there are instructions attached to the oven, near the regulator. We've lost those instructions and need to know what size orifices we need, and in which burner each goes. Can someone help us with that?
    Scholar:
  • 155 Answers
Not sure of the size of the orifices, but the natural gas orifices should be larger than the propane orifices.
Posted on Dec 30, 2013
  • Nate Richardson Dec 30, 2013
    Thanks, Bill. We have the natural gas orifices, and are just trying to confirm which one goes to which burner. We've used deductive reasoning and are putting them in now. Thanks for the comment.
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
MNTECH
  • 1543 Answers
SOURCE: natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Posted on Apr 20, 2009
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile Oven converted from natural gas to propane. The tech changed the orifices and now the flame is to high. Any quick solutions.
The regulator needs to be adjusted, but if you do not have the proper equipment you should not try to make that adjustment...to bad the tech. did not do a good check before leaving...I ALWAYS fire every burner and check out everything before leaving, it is just too dangerous not too...
heatman101
Sep 13, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert back to natural gas
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need a conversion kit for my GE XL44 range
go to www.marcone.com they should be able to help you call the toll free number
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Soot is forming on my gas fire. it is fuelled by lpg. ive tried using calor gas instead of a cheap gas but its still the same . help` its driving me potty !!!!!!!!!!!!!!!
the range is not converted or converted proberly to lp gas. they are sold to be used with natural gas and needs to be converted to handle lp
Oct 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
226 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
