Question about Behringer U-CONTROL UMX61 Keyboard
Cant get playback from umx61 behringer
When i play a few keys like for a drum riff or bass line i want to store them in the midi so i can play them back without havin to play live. so it would be like they are looping. then i can play about with other synths rythms etc while the drum riff will be playing over and over. or even when i get a good drum riff then i can record it in to cubase sx on my pc.the manual doesnt tell you how to do this please help. cheers
fire sine
  • 382 Answers
SOURCE: Not working
http://forum.cakewalk.com/printable.asp?m=745403
Posted on Nov 10, 2007
Siliconchip
  • 52 Answers
SOURCE: Behringer amp
Hello pare ko.
EP2500 is a pro amp, manufacturer says that. Notorious to me.
Got 5 of these for repair. Clip is of course cause by too much
signal from source. If the amp is still clipped or on protect even w/out
signal in, time to open and do repairs inside. usually a MOSFET
inside P50N06 (50V-60A) is kaput. or MJE15033G and MJE15032G.
Now if blowing main Fuse, main txistor 2SA1943/2SC5200 maybe gone.
Read carefully the setting of your dip switches setting at the back.
This amp can drive 750 watts/ch@4 ohms.
Good Luck From Siliconchip
Posted on Sep 11, 2008
  • 5603 Answers
SOURCE: i have a behringer Xenyx 1622 mixer and am using
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Posted on Apr 27, 2010
  • 5603 Answers
SOURCE: Hi there! I just needed a keyboard to use for my
The sounds do NOT come out of that keyboard. That keyboard emits MIDI digital signals that are sent to a device that genrates the sounds. That can be a sound module such as fopr instance an Emu Proteus which generates audio... OR a computer that has MIDI input and a suitable sound generating software like Ableton or even using the built in voicing in compouter sound cards (general MIDI).
Posted on May 25, 2010
  • 5603 Answers
SOURCE: Behringer B1800 subwoofer quits few times and then
Check the internal wiring. There may be a loose connnection and this is VERY hazardous to you amp !!!
These may also have a self reseting fuse and that MAY be damaged.
You should discover the problem when you open up the unit.
Posted on May 31, 2010
Some of the keys on my keyboard are not working
How long did you have it for? Did you buy it new? on average 3% coming out of manufacturer is malfunctioning. You could have gotten one from that 3%. I recommend you return the keyboard where you got it and before you leave the store with the new one, try it in front of the salesman.
Oct 02, 2013 | Behringer U-CONTROL UMX61 Keyboard
Broken usb port behringer umx61
Broken ports may require service from an authorized Behringer dealer (is still under warranty). However, if there are no breaks in the plastic housing, then you may want to try opening the bottom of the case, and doing repairs yourself. I would need more details about your reference of "loose" so that I may help you better. Good luck! :)
Sep 05, 2012 | Behringer U-CONTROL UMX61 Keyboard
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
After a few minutes of starting a new piece of music, i go to play it on Finale, and a window pops up saying that Finale Songwriter 2010 encountered a problem and needs to close. This also happens whenever...
This also happens whenever i press the playback button.
Then don't press it
Also check your midi settings that would explain the crash on play issue, sorry I cant help more but I use sybalius on windows
Nov 17, 2010 | MakeMusic Finale SongWriter 2010 Full...
I have nuendo 3 hooked up via midi out by a m-audio 1X1 usb midi cable to a yamaha qy70. The QY70 is receiving the signal, but, everything is coming in on midi channel one. Whenever I set the drums on...
the changes which you make should be selected and set to a default mode.other wise the changes will get deselected to what it was default before automatically. in some cases its the software issue,.so reload the software again as new and check out. also check the connections its a rare chance but many times its possible,
check out.keep updated.thanks.
Jan 25, 2010 | Steinberg Nuendo 3 for PC
Hi there! I just needed a keyboard to use for my band and found the umx61 from behringer at an online shop and for that price and all the extra functions you get for that small ammount of money I thought...
Nov 29, 2009 | Behringer U-CONTROL UMX61 Keyboard
MacG4+Reason+Umx25 Behringer
Your problem lies in Reasons, and you need to setup your audio to except audio from outside sources. This should correct the problem without interrupting your midi. Good Luck
Fehdi
Apr 16, 2009 | Computers & Internet
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
Behringer U-CONTROL UMX61 Keyboard Logo
127 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Steve
Steve
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
