Question about Kenmore 44072 Front Load Washer
Dark grey smudges on clothes from a Kenmore front-load washer.
Hi, My Kenmore front loader washing machine is leaving dark grey smudges all over the washed clothes,sheets,towels,etc. These marks aren't in any noticable pattern - in some places, they're dark and heavy,but in others they're lighter and larger with a smeared appearance. As if that wasn't enough, sometimes a piece has a pattern of grey small round circles that matches the holes in the drum (as though dirty grey water was staining the item from the outside wall of the drum !) These marks all come out when washed in a laundromat washer.
The model number is 417.43042200.
I'd appreciate any ideas. Thanks.
  • Stephwomble May 19, 2009
    My machine is leaving grey lines on my clothes...not all in the load but some. they are random in length and not a straight line. I have cleaned out the drum and seal around the door to make sure it was not mold. I also used Affresh right before my last load and it is still doing this. I use powder for he machines.
5 Suggested Answers
SOURCE: Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
Posted on May 04, 2008
Lumpy816
  • 246 Answers
SOURCE: Do I need to descale or rust treat my Washing Machine?
As another tech is assiting you and I have not received a response, I'm closing this one off my list.
Posted on Jul 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore heavy duty tumble washer is leaving a
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
caroldon
  • 17130 Answers
SOURCE: My washing machine stains my
You will need to check in the first place the water inlet that connects the washer as if the pipes are rusted then it will be bringing to the washer some stains along with the rust . So allow the water to be collected and checked outside and then connected to the washer and checked.
next check on the sides of the tub /drum for any rusted parts or foreign objects that are lodged into the drum.
Finally make sure that the tub is clean, the vents and all the sections connected are brushed off with light vinegar and detergent.
Posted on Feb 05, 2011
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
My kenmore he2t 8540911 drum will not spin.all of the time and leave the clothes wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Kenmore 43142 Front Load Washer
2002 Kenmore front load washer 42042 is leaving large black smudges 3-4 square inches each and streaks, and dot patterned stuff of the same on my clothes. This unit is stacked . Is it repairable for...
Two possibilities come to mind. Too much fabric softener, or
the black rubber door seal. Try rubbing the seal with a paper
towel to see it it smudges. Try cleaning with bleach or alcohol,
then rinse it thoroughly with water.
Feb 04, 2011 | Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My kenmore washer front load is leaving stains that look like soap spots or grease (not black) on my dark colored clothes red blue green navy I don't use fabric softner and I use less than half of the...
periodically this has happened in a white sheet wash in my kenmore front loader series 417. we ran the washer empty with washer cleaner and blackish water was ejected from the pump. Another site suggests mildew under the drum . I am wondering if some oil from the unit is leaking in on a high spin cycle where the load is too full.
Oct 29, 2009 | Kenmore Washing Machines
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Kenmore 44072 Front Load Washer Logo
245 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
