Question about eMachines D6405 160GB Hard Drive Replacement
Replace hard drive emachine d6405 - eMachines D6405 160GB Hard Drive Replacement
How to take pictures off dead emachine
The hard drive must still be working to get the pictures off. The best thing to do is remove the hard drive from the machine and use either an external USB type case to mount the drive into so you can use another computer to explore the drive or there is a tool that just plugs on to the drive with a USB cable and power supply built in that will serve the same purpose. You must get the appropriate type to match the drive type which could be either IDE or SATA. SATA drives use the small cable and IDE use the wide ribbon. If the hard drive is not working, you would have to get specialized and expensive company to retrieve the data from the drive.
Jan 14, 2014 | eMachines Emachine T1742 Power Supply...
Replace hard drive
The eMachine T3995 hard drive was originally an IDE 250GB drive. These drives are obsolete and hard to find.
I suggest using the following Generic IDE to SATA device on Amazon for about 7 dollars and then replacing the IDE drive with the SATA drive of your choice such as the 320GB Western Digital Blue listed on Amazon at about 25 dollars. Both IDE and SATA drives mount the same way.
Feb 08, 2013 | eMachines T3995 Power Supply Part Number...
My emachines says it cannot find the hard drive and i get blue screen after i restart it
Things to try:
1. Remove and reconnect the hard drive.
2. Remove all USB attached devices. Like other hard drives and anything non-critical.
3. Wipe and reinstall Windows once the hard drive is properly installed.
4. Replace hard drive if bad.
Jan 22, 2013 | E-Machines eMachines Desktop PC
I need the wiring diagram for emachine model D6405
Usually it is in very small print right on the motherboard next to the pins, use a flashlight and/or a magnifier to see what order the pins go in. The hard drive light will say HDD, power will say PWR, etc.
Nov 26, 2011 | E-Machines eMachines Desktop PC
When i turned my emachine on it was making a funny noise and won't boot up
Sounds like your Hard Disk Drive is Bad and you will have to replace it this link will tell you how to install a hard drive
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Sep 08, 2011 | Acer eMachines 3502074 Netbook
Replacement of hard drive
The first link is to download the step by step instructions on how to replace the hard drive on your model. The second is the contact link for e-machine ,as I found no restore disk as a download.
http://www.emachines.com/support/service.html#eurpp
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2824
Apr 22, 2009 | E-Machines (T2824) PC Desktop
Emachine locked up won't start
Hard Drive Clicking = Going Towards End Of Life
Put the hard drive in a working pc and get any important data off it , its about to die!!!!!!!
Get a new hard drive and do a windows reinstall (not like you have a choice)
not sure about the rest though sorry
Jan 04, 2009 | E-Machines eMachines Desktop PC
Emachine T5026 installing a new hard drive.
place the harddrive over or under the old drive.
a IDE cable most be connected to the harddrive and to the motherboard.
and a 4-pin power cable most be connected.
CS.
May 18, 2008 | E-Machines eMachines Desktop PC
Files off my discs wont open or copy to my new pc
on these matter i have identified two possible cause of your problems.
1. You CD/DVD (discs) maybe damage.
2. Your CD/DVD rom was not able to read.
Solution:
1. to sure that the DVD/CD rom is functional try other discs (Any discs that that is clean and no traces of damage.(if work on another discs so DVD/CD rom is good if don't work your discs is good)
if not solve the problem maybe your system had a problem. update me in case.
Dec 16, 2007 | E-Machines D6405 (RBD6405) PC Desktop
eMachines D6405 160GB Hard Drive Replacement Logo
15 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
