Question about Kenmore 600 6965 Electric Dryer
Dryer model 110.C66822694 wont start - Kenmore 600 6965 Electric Dryer
2 Suggested Answers
  • 35 Answers
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Posted on Jun 07, 2009
I have a whirlpool gold gas dryer model#GGQ8858JT1. When I push the start button the dryer starts and spins but the heat does not come o
does the igniter glow? If not check for 110 volts at igniter .
Check for 110 volts at gas valve if no volts check hi limit thermostat , operating thermostat, safety switch on motor,
the coils on the valve & the timer contacts that feed the voltage to the burner.
Mar 02, 2014 | Whirlpool LGV4634JQ Gas Dryer
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Dryer wont start kenmore ultra fabric care model # 110/87880800/78808
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 04, 2011 | Dryers
Kenmore gas dryer 110 series wont start
heatman101
Nov 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore Model 110. 70970902990 motor dogs out after 10 to 15 min.
The roller for the dryers drums belt tensioner has a freezed up bearing causing this
May 07, 2010 | Dryers
Kenmore dryer model # 110. 79902890 press the
you have a problem with a component called a capacitor.the capacitor stores an electric charge.this charge gives the motor the "kick" needs to start.if you have a faulty one the motor will hum because it cant turn.it should only be replaced by a competent appliance technician.
Oct 07, 2009 | Dryers
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Kenmore 600 6965 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
