Question about Bosch Refrigerators
Fridge leaking yellow liquid - Bosch Refrigerators
My refrigerator is located in a fold garage ... A whitish liquid is leaking from the bottom of it ... Any idea what could be wrong
What you're seeing may be the oil in the system if the refrigerant system has failed leaked out - which I suspect it has.
Refrigerators do not work well in cold areas, as when the fridge's interior is cold and the compressor shuts off, the ambient temperature causes the refrigerant gas to turn to a liquid and return to the compressor. When the temperature inside the fridge rises enough to turn the compressor on - it fails catastrophically as a compressor can only compress a gas, not a liquid.
Mar 06, 2015 | Refrigerators
Leaking yellow fluid
Dog or cat peed on it. Or liquid is coming from washer. There is no liquid in a dryer to leak out.
Sep 11, 2014 | Whirlpool Dryers
Screen leaking sticky liquid
Yes...the liquid is toxic. LCD solution can be highly toxic and ought not be touched. I would definitely put it somewhere where your cats can't get close to it, and bring it to a repair shop.
Jun 04, 2012 | Dell Latitude D630 Laptop Computer PC...
I think my cooling unit is shot, but about the same time of my fridge going out I had what seemed like a water leak. It was in a closet no where near any water lines,but on the same side of the closet...
These RV fridges are filled with ammonia, sounds like your unit has a leak, You should remove your fridge and possibly get it repaired , refilled and tested, or find a used one, These units are a few $$$$.
Oct 12, 2010 | Dometic RM2652 Refrigerator
Fridge and freezer not getting cold.
Is the yellow substance oil? I need the sears model number also for example 312.65989 That way I can picture just what you have on this end. Sea Breeze
Feb 21, 2010 | Kenmore Refrigerators
Why the engine is overheat, and occasionaly i see yellow liquid leak in the left side
Yellow liquid? as in the color of your anti freeze? You may have a blown head gasket?
Jul 16, 2009 | 2003 Kia Sorento
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
Battery charger-leaking yellow liquid
No, it will not be safe to use it again, and yes, the yellow liquid is VERY DANGEROUS. Please do not use it again, you need a new charger.
i dont think the batery was affected, but if it was, you also need to throw it way and get a new battery.
Jun 07, 2008 | Sony Ericsson Z710i Cellular Phone
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
253 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
