Question about Maytag Maxima MHW6000 Granite Front Load Washer - MHW6000XG
Maytag MHW6000 door lock light on, other lights off, unplugged and replugged
SolutionGuy
  • 331 Answers
SOURCE: Maytag front load 9700
First things first... please follow this link to see if your machine is part of Maytag's recall... http://www.washerrecall.com/ or this site for details on the recall... http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html
Posted on Aug 19, 2007
SOURCE: Maytag Neptune - door locked, clothes inside, lights are on
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Posted on Oct 04, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
  • 58 Answers
SOURCE: I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Posted on Mar 09, 2010
Whirpool washer front end loader lock light is on. but i can open the door the wash is empty. unplugged replugged it and tested the GIF the plug its in had power too, other wise the light to the lock...
unplug the washer, remove the lower front panel, put your hand under the front panel and pull a little lever behind the door lock mechanism and pull the door open.
Feb 05, 2011 | Whirlpool Washing Machines
Door lock light flashing, door will not open
if it has a kick plate on it take it off and see if the filter is clogged
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Mar 09, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag MAF1300AAW Error code 4. The machine starts to fill then drains which is repeated several times before eror code 4 appears.
Hi this searstechtoo I did some research on similar american models and will paste what I found for you.
Will Not Lock
• Door not all the way closed or not properly
aligned. Possible laundry load is too large to
close door.
• Place washer into Service Mode and check for
diagnostic codes 4 &18.
• Perform Board Output Test. Check door lock
system.
• Check electrical connections at lock switch
assembly and machine control board (CN2).
Cn2 is a thermistor used in a wax motor to control the lock and unlock feature of the door.
I would start at the lock and trace the wires then unplug and replug them.
Thanks SearsTechToo
Oct 04, 2008 | Maytag Washing Machines
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Help!!
Have you tried unplugging the fridge and then replugging it in? Sometimes a power down/power up cycle will clear errors and get it started again...
Aug 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag Maxima MHW6000 Granite Front Load Washer - MHW6000XG Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
