Question about Pioneer FH-X700BT
Wiring diagram for a pioneer fh-x700bt
I have to wires on the harness that is orange & white stripe & another that say dimmer ground ,but those wires are not on the receiver harness in the back of unit
SparkGap
  • 363 Answers
SOURCE: Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Posted on Sep 21, 2007
bkackerson
SOURCE: Pioneer DEH-P30001B Car Receiver- recently
the owner's manual is available online on the pioneer website at http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP3000IBOperationManual1023.pdf
the first 51 pages are in english
Posted on Oct 30, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
smarthome2
  • 1114 Answers
SOURCE: What is the orange wire for on the pioneer DEH-2800MP?
If you have a blue with white on it or a solid blue lead, I'm at a loss, however the manual even states that colors may change w/o notice. Best way to tell is to use a meter, black probe to ground and red probe to the orange. Put it on DC voltage then turn the ignition to acc. then turn on the deck, my hunch is that it's your amp remote turn on wire for an external amp or it can be used for a power antenna. Voltage should be 12.2-13.8dcv. Hope this helps
Posted on Jun 24, 2009
  • 24 Answers
SOURCE: i cant find a wiring diagram to install my new
Operation and Installation Manual: http://akamaipix.crutchfield.com/Manuals/130/130AVHP400.PDF
Posted on Sep 17, 2009
Trying to install the fh-x700bt into my 2005 gmc envoy. I am using the GM1590AB and the GM05B + Red Wire. I was able to connect all of the speaker wires correctly. I'm having trouble beyond that. The red...
The amplifier is in the passenger side rear quarter panel.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jun 29, 2014 | Pioneer FH-X700BT
How to connect pioneer fh-x700bt to a 2004 ford explorer
You need to buy a wiring harness compatible with your vehicle. The wiring harness will connect to your vehicle OEM plug and the other end you need to splice it with the wire that came along with your car stereo.
Apr 16, 2014 | Pioneer FH-X700BT
Metra wiring diagrams 70-1761
I believe that the orange dimmer wire should not be connected to anything. I taped my orange wire and left it unconnected and it worked.
Dec 13, 2013 | Pioneer FH-X700BT Double-DIN Car Stereo...
Need wiring diagram for the FH-X700bt
Page 16 of the owners manual tells you the color and function of the wires from the stereo are: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/FH-X700BT_OwnersManual112712.pdf
Oct 21, 2012 | Pioneer FH-X700BT
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
I need the wiring diagram for a pioneer avic-n2! i need to know which colors do what!
Pioneers wiring is easy. Red is ignition-Yellow is battery-Black is ground-Blue is remote for amp or antenna-Orange is illumination-Speaker wires are usually grey, grey w/blk stripe-white, white w/white stripe-green, green w/blk stripe-purple, purple w/blk stripe. Green and purple is rear, white and grey is front
Sep 18, 2010 | Pioneer AVIC-N2 Car DVD Player
We cant find the power cable in our rover 420 sdi to re-wire a new stereo..the blocks have been cut off the stereo we brought so no clue as to wats wat and no wire diagram on top of stereo
If its a aftermarket stereo, the red wire is ignition, yellow wire is constant 12 volts, & black wire is ground. The speaker wires should be purple + & purple w/ black stripe - / white + & white w/ black stripe - / green + & w/ black stripe - / gray + w/ black stripe - /....then blue is for power antenna. Thats most aftermarket radios, some have orange for a dimmer but it depends on the brand.
Mar 28, 2010 | Pioneer DEH-P6600 CD Player
Wire diagram pioneer deh-p7200
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
Mar 07, 2009 | Pioneer DEH-P7200 CD Player
PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
orange-12volt constant-memory
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Mar 04, 2008 | Audio Players & Recorders
Pioneer FH-X700BT Logo
161 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
