Mccallister I am trying to source the following for my MacAllister wet and dry take off vac 220-240v 50Hz 1250W IP24 serial number 0001053 CODWDTOV 05160518 Foam Filter 905-03 Dust Bag Standard 906-03 Cartridge Filter 905-01 Dust Bag Fine 906-04
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Posted on May 06, 2009
  • 8404 Answers
SOURCE: what if i use my wet dry vac to pick up water
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Posted on Oct 13, 2009
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
SOURCE: how to set up wet dry vac for water pick up
you take the filter off and empty it.
Posted on May 01, 2010
SOURCE: How do you remove the filter from Rigid wet dry
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
Posted on Aug 14, 2010
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Looking for owners manual do I need to take off the filter to vac fluids
Go to the Craftsman website, they have free manuals you can download. type in the model or serial number
Jul 29, 2011 | Craftsman 17026 Wet/Dry Vacuum
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
May 06, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Nov 05, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
