Question about Canon Pixma iP6600D InkJet Photo Printer
EEPROM error [6800] - Canon Pixma iP6600D InkJet Photo Printer
Canon MP610 Error 6800
According to the service manual an error has occured writing to the eeprom on the logic circuit board. I would look at the logic board as a culprit . You may need to check the voltage is correct at the power point and matches the printer required supply voltage. What worries me is what caused the logic board to fail and make a burning smell. Could be a faulty voltage regulator supplying the logic board or a fault in a power board..
http://internaute.free.fr/depannage_canon/mp610/mp610-sm.manuel.reparateur.pdf
Aug 13, 2014 | Canon MP610 Photo All-In-One Printer
Error 6800
According to the service manual error code 6800 means that "A problem occurred in reading from or writing to the EEPROM". The suggested parts replacement is the logic board. See page 12/64 in the service manual.
You find the service manual here: http://elektrotanya.com/canon_pixma_mp560sm.pdf/download.html and the parts catalog here: http://elektrotanya.com/canon_pixma_mp560pc.pdf/download.html
For download of files from electrotanya see this post for instructions: http://www.nifty-stuff.com/forum/viewtopic.php?pid=61324#p61324
I think that turning the printer off and disconnecting power for some minutes and then reconnecting power and turning on the printer doesn't make the error go away?
I don't know if clearing the EEPROM from service mode will remove the error, but you lose the printer history and absorber counter value in doing so. You might also have to uninstall and reinstall the printer to get the display language back to English. Probably the logic board error will prevent the printer from starting, so no service mode operations will be possible?
If you want to give the service mode a try, then I recommend studying the service manual p. 47/64 to 54/64 incl and this thread: http://www.nifty-stuff.com/forum/viewtopic.php?id=7416
Nov 02, 2013 | Canon PIXMA MP510 All-In-One InkJet...
I have canon MP510 and I have a probem because my canon have a code 6800. What can I to do? Pleas for helps
Unfortunately error 6800 is an eeprom write error. You will not be able to cure this without replacing the scnt board (main board). The cost of a new board and labour would almost equate to the cost of a replacement machine. Cut your losses and buy another machine. Srri
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Green and orange light flashing and on the screen was Service Error 6800
Service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Dec 02, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Error code 6800. Lights on computer are flashing and there is, what appears to be Asian lettering on the screen.
The service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Oct 16, 2010 | Canon MP970 Photo All-In-One InkJet...
Mech error 12 in kodak 6800
Mech error 11 in kodak Problem with the Kodak Photo Printer 6800 Thermal
Sep 18, 2010 | Kodak 6800 Thermal Photo Printer
Hej I get an error code 6800 Regards Ivan
Mar 20, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon mp530 printer had a check cartridge error U052, but then it changed to check printer 6800 and it won't work. is there a cure?
6800 must be EEPROM error.Try this:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (you're still holding the POWER button during this). The printer mechanics will move momentarily. You're in SERVICE MODE now.
Press the RESUME 3 times.The lamp will alternate color with each key press.Then press POWER button.Wait 5 mins and press POWER again, the printer will turning off.
If this not help printer may need service.
Oct 15, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Jul 03, 2009 | Kodak 6800 Thermal Photo Printer
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
75 people viewed this question
old marine
old marine
