Electrolux w3105h error E13
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
What does error code 04e mean on the Electrolux w3105h mean
04 ERROR. LOW TEMPERATURE The temperature is below the lowest value allowed (open circuit in temperature sensor).
Jun 07, 2016 | Electrolux Washing Machines
I have a electrolux We71 washing machine. What does mean E13?
Go to this link: And under the heading: Scroll down past the boxes and you will see your code.
Needapplianceparts com
Jul 03, 2015 | Electrolux Washing Machines
My Model # EIFLS60JIW0 Serial # 4C21503809 alerted to call customer service error code E13. Can you advise what this code would be in reference to
Dee,
Here is a link to a website that has possible error codes for your machine. I used your model number and went to a different site to find out what brand you had and I am assuming that this is for an Electrolux washer. http://appliance911seabreeze.com/Frigidaire_Error_Code_Booklet.pdf
Mar 02, 2015 | Washing Machines
Electrolux W3105H
error codes http://www.needapplianceparts.com/electoluxfaultcodes.aspx
Aug 05, 2014 | Washing Machines
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My electrolux IQ Touch came up with error code E13 first time using it what does this mean
The solution for E13 is to unplug the Electrolux washer for a few seconds (10-15 seconds) then plug it back in and press cancel. Then it should reboot itself. It's some problem with the computer which just needs to be reset
Nov 23, 2009 | Electrolux EW1000i Front Load Washer
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
