Question about Sony Handycam CCD-TR818 Camcorder
A beeping noise goes off, when i put in a tape, like it starts beeping then ejects it out, and the screen shows "remove casset", ive already tried the dry video head cleaners, but it ejects that tape back out too, what do i do? My sony CCD-TR400 does the same thing, but not all the time. It will buzz with a spinning sound, then beep, then eject the tape. No teardrop, just a flashing upward pointing arrow on the screen.
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
SOURCE: NO PLAYBACK
According to Sony support, you should follow these next steps: 1. Ensure the batteries are fully charged or the AC power adapter is connected. 2. Remove any media (tape, Memory StickĀ®, DVD, etc.) from the camcorder. 3. Properly reinsert the media. 4. Ensure the media compartment is properly closed. 5. If the problem continues, try inserting different media. In addition according to your post it is very likely that you busted the tape mechanism. In this case only a certified technician can help you. I hope you work it out
Posted on Apr 25, 2006
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
ctf1800
  • 4402 Answers
SOURCE: inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Posted on Jun 16, 2008
My dsr-45 no eject cassete
please follow this :-Remove the case, remove the mechanism cover, cut the mangled tape in pieces and take it out gently - you are going to have to rotate some part to untangle most of it. With all the tape that's out of the cassette removed from the mechanism put the unit back together and eject it.
i hope this will be helpfull to you .
goodluck.......
Feb 02, 2011 | Sony DSR-45 Mini DV VCR
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Will not close while tape is in ejecter,alarm beeps and screen says (remove cassete), but will however close without tape??? canon mv830i digital camcorder...
Several things could be happening...the tape is backwards, upside down, inverted or just wrong type since it closes without it. Next check to see on the inside if something is jamming the tape. While it closes without a tape there could be something that jams when a tape is inserted.
May 09, 2008 | Cameras
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
A beeping noise goes off, when i put in a tape, like it starts beeping then ejects it out, and the screen shows "remove casset", ive already tried the dry video head cleaners, but it ejects that tape back...
Does the unit say anything about moisture? This sounds like a moisture fault. Leave the unit open for a day in a dry area and try it. If it is moisture and everything is OK this should solve your problem. If it doesn't solve your problem you could have a bad moisture detector. This is a small square metal looking device near the video drum with two wires hooked to it. It's job is to protect the camcorder and keep it from damaging tapes when moisture is present in the unit. The simplist way to verify if it is defective is to jump a wire across the two connections and try the unit. If it works this is your problem and you will need it replaced. A good repair shop should be able to do it for about $50 US. Two websites which give free estimates are http://www.videotech.com and http://www.camcorderrepair.com Good luck.
Jun 16, 2006 | Canon ZR100 Mini DV Digital Camcorder
Sony Handycam CCD-TR818 Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
