Question about Intel DH55HC Motherboard
Vga onboard after starting my pc some time display disappear n some time display shows red blue pink purple color and some time pc never start . i change my ram power supply harddisk but still i get this problem
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
You may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Posted on Dec 31, 2013
edgood1
SOURCE: vga display problem
There is one pin/wire on the VGA connector that translates to the color red on your screen. If you aren't seeing any red, I would suspect that there is damage to the integrated VGA connector on the motherboard, or a component failure in the circuit.
These are great desktop boards.
The Video bus on these boards are shared between the integrated (onboard) video card and port and the AGP slot. This means that you can only use one or the other. When you install an AGP card in the slot it overrides the integrated video including your problem.
If you are good with electronics I'd take a look at the board under the scope and look for damage.
I would rist check with intel on the warranty. You may be surprised. I've had several of these replaced via RMA through intel. They are a bit older but still by desktop board of choice.
Posted on May 21, 2008
SOURCE: pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Posted on Jan 12, 2009
dagr81
  • 59 Answers
SOURCE: VGA onboard driver
dear friend
i believe you ave intel p4 1.8-3.0 or celeron 1.7-2.4 cpu
goto
intel.com
choose downloads
choose motherboards
select any board of series 865
select os
download display driver
done...
Posted on Apr 11, 2009
  • 140 Answers
SOURCE: I have facing a pequliar problem with my this
Plz check the SATA power connector , if possible change it and recheck else your motherboard problem
Posted on Sep 29, 2010
  • 278 Answers
SOURCE: I have Intel D845GEBV2 motherboard
may you need the video driver
scan your pc from here www.ma-config.comand if you need a driver download it fromthe same website
Posted on Jun 15, 2011
Cannot get reds or purples to accurately show on display or when developed in hard copy. Reds show pink. Purples show blue. Tried a number of things but no luck
Looks like a problem the colour balance. But to help you more, I need to know what model Fuji you have.
You are sure there is no smudge on the lens? and there is no damage to the lens?
Feb 26, 2015 | FUJIFILM Cameras
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a while and then shows the same problems.tried different graphic cards and get same result or would show all...
http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-D667&s=775
Select your operating system. If this model has onboard graphics, download fresh VGA driver, remove your graphics card and see if you can get any results.
Nov 23, 2009 | Computers & Internet
Can we stop it from changing color
Hello bd1340,
The JVC KD-SC500 ships with the color selection set to "ALL DEMO" which alternates the colors approximately every 6 seconds.
To cancel the "ALL DEMO" and select a single color display, go into PSM mode by pressing and holding the SEL Button until the display changes. Use the left/right rocker until COLOR is displayed. Turn the VOLUME knob to select the color you want: Blue, Ocean, Purple, Pink, Rose, or Red. Press the SEL button again to exit PSM mode.
Hope this helps.
Aug 22, 2009 | JVC KD-SC500 CD Player
Incorrect & missing colors
I would try purchasing new ink - especially if the printer and inks has been sitting unused.
May 14, 2009 | Laser 3115cn All-In-One Printer
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Monitor Problems
1. check the monitor on other PC if the problem is same that means the VGA cord or the Pins have gone faulty.
2. Just bend and cable and keep monitoring the display where it stablises to normal, and tie thw cacle at that point with something.
Apr 29, 2008 | Computers & Internet
Intel DH55HC Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
