Question about Whirlpool Cabrio WTW6600SBK
Maytag giving f54 code
Goes to full spin then makes a noise then stopes gives code f54
4 Suggested Answers
  • 1294 Answers
SOURCE: waher makes weird noise
Click on Whirlpool (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Nov 30, 2007
SOURCE: Won't spin or agitate, makes grinding nois only.
Pick up a copy of the Nov."The family Handyman" magazine. Pg. 60 shows your problem and how to repair it. Most likely it's a broken coupling,
Posted on Oct 29, 2008
SOURCE: Maytag mav6250awq makes loud noise when agitating
gearcase.
Posted on Nov 05, 2008
Makes clicking noise spin cycle
it may be any part of the balance mechanism under the machine..remember if you did not balance (level) it prior to installing, it has to self level on its own..this usually calls for some noise in the linkages when spinning..
Mar 04, 2014 | Maytag MAT15MNAWW Top Load Washer
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
F54 code
It is detecting a high current load when trying to turn the tub. Lift the top of the washer by using a putty knife and insert it between the top and front panels about 3 inches from each side, push in the clip and lift the top. You will find a tech sheet glued to the inside of the front panel in a plastic bag. Go to page 3 and look up your error code, it will refer you to page 4, test #3. I explains how to test the motor assembly.
Oct 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Hello i have a maytag neptune front loader that ive had for only two years and it was making an extremely loud noise when spinning now it has stopped spinning completely and my clothes are still soaked...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Maytag Washing Machines
Washer makes noise when it goes into spin cycle. the faster it goes the louder the noise gets.
Sorry, just as you explained bad news it sound like the bearing are giving out and would req an overhaul the possibilty of an very expensive repair.
Jan 01, 2010 | Maytag Neptune MAH6500A Front Load Washer
It will not spin sometimes and door is locked plus why researching it I have found there is a recall for it. What should I do fix it or give it back to maytag and how does that work? Right now it is...
if there is a full recall on it  which i doubt--maytag are obliged to replace it for you--but  anyway maytag will probably repair it for u foc--just make enough noise about it
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
NOT GOING INTO FULL SPIN
Check the water pump and see if anything is clogging it up.
May 01, 2009 | Washing Machines
Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
Whirlpool Cabrio WTW6600SBK Logo
Dan Webster
Dan Webster
Sal De
