Question about Bose Radio Communications
Replacement ear caps - Bose Radio Communications
Agitator not working but spinner is fine how can i fix myself?
the dog ears are wore out look at a vid on it type in dog ear re[placement washer perhaps that will lead you to one if you open the washer the center top of the agitator pull off the cap there should be a bolt head down there unscrew it and pull out the top area the dog ears will be there three little plastic thing looking like teardrops with small fins to catch the agitator to move it they are worn out cheap to replace
May 14, 2016 | Washing Machines
What could cause an engine in a 1997 jeep grand Cherokee Laredo to blow the oil cap completely off the valve cover on a straight 6 cylinder
No ventilation to the block....check pvc valve...check for broken parts under valve cover. Or the ears that hold the cap in are missing cap is the wrong size should have 2 ears on cap like to thread.....p.v.c....positive crankcase ventilation
Nov 26, 2015 | Jeep Cars & Trucks
Stopped agitating
Its probably what they call "dog ears". My washer was doing the same i took off the cap on top of the agitator and un screwed the bolt. I grabbed that white piece out and there were four little plastic pieces that looked like dog ears and i replace them for under 1.00 and mine was fine after that.
Aug 25, 2011 | Kenmore 22422 Top Load Washer
Only the bottom agitator works, not the top
replace the dog ears in the upper part of the agitator not expensive and not hard to do ,,,, pop the cap off the upper agitator remove the 7/16 bolt and lift off the upper part and replace the plastic dog ears and reinstall!
Mar 08, 2010 | Kenmore 12502 Top Load Washer
Agitator does not work washer goes through all the cycles it just dos not agitate model number 110.28732700 SN: CW2040704
your agitator dog ears are worn, can get some from your nearby appliance shop or order from Repairclinic.com,,,,,not hard to replace,just pop cap off with a screwdriver then with a 7/16 socket ,ratchet and extension remove the bolt in top of agitator then lift out the dog ear assembly and replace,be sure to look at the grooves your dog ears lock onto see if they are bad
Feb 16, 2010 | Kenmore Washing Machines
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Removing agitator from Kenmore washer
On my Kenmore 110.28922790 Washer, after removing the cap on the agitator, only the top of the rod was visible. The plastic cup over the rod has a square insert which my 5/8 in. flat wood drill bit fit into. Turned it counter clockwise and unscrewed and removed the plactic cup. Then the cam assembly with the wornout dog ears lifted out. The bolt did not need to be replaced to replace the dog ears.
Aug 06, 2008 | Washing Machines
We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
The agitator 'dog ears' have worn out. Very easy to replace.
  • Remove fabric softener or protective cap on top of agitator
  • Remove center bolt securing agitator.
  • Lift out agitator and replace dog ears.
Jun 23, 2008 | Whirlpool Washing Machines
Lost ear phone rubber caps (phillips brand)
You can purchase new rubber caps for Philips earbuds on ebay from seller "auction2world". They are called replacement earbud cap. Unfortunately, you need to purchase the whole set of 3 different sizes.
May 17, 2008 | Lands Phones
Toshiba CF36G50 Noisy when you turn it on
that sound is comming from the tube anode it is leaking you have to discharge the high voltage from the anode cap,then take off the cap clean the area with alcohol and put some red or clear silicone on the cap and anode connection replace back the cap on the tube leave to dry for about half hour,this will remedy your problem,no more static.good luck.
Jul 05, 2007 | Toshiba CF36G40 36" TV
Radio Communications Logo
14 people viewed this question
Top Bose Radio Communications Experts
 Grubhead
Grubhead
DIY-Dan
Level 1 Expert
Owen Barnes
Are you a Bose Radio Communication Expert? Answer questions, earn points and help others
