Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
How to set call forwarding - Vtech DECT 6.0 Cordless Phone with Digital Answering System
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
How do I forward yahoo email automatically to another email address
You can obviously forward your emails to the other account; all you have to do is enabling of the forwarding message settings in your account. All you have to do is "click on settings":
If you are using gmail you will see "forwarding imap/pop or forwarding tab"; click on it you will have to enter the yahoo email address on which you want to forward the mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
If its outlook, you have to go for the "email forwarding tab" and enter the yahoo mail address on which you have to forward your mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
You also can set up filters to forward messages that meet specific criteria. You can create 20 filters that forward to other addresses and can also maximize your filtered forwarding by combining filters that send to the same address.
Apr 20, 2013 | Yahoo Mail
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
I need help setting up to forward email.
To set up email forwarding on your Gmail account, log into your account and select Email Settings from the top-right corner of your screen. Select the link that says Forwarding and POP/IMAP and then click "Add a forwarding address."
Clicking on the button should pop up a dialog box that you can use to enter the email address you want to forward your email to.
Mar 25, 2011 | Google Gmail
I'm not sure if the problem is the phone set or the PBX. I have programed the phone set to forward all calls to extension and it works great. But I can not get it to toggle the forwarding on and off...
Check out the instructions for setting forwarding no answer. *7104 xxx # sets the forward and the time it requires to forward is settable in the *713 ss where ss is the number of seconds from 00-99.
A ring cycle is 6 seconds, so 24 would be about 4 rings. Once you set forwarding, you really don't have to cancel it, as even if someone is on the phone, the call waiting and display tell you who is calling and you have the timer time answer or ignore the call.
Carl
Feb 15, 2011 | Panasonic KXDT333 Phone
I want to forward my faxes from my Panasonic machine to another # temporarily.. is this possible and how?
Fax forwarding You might want to set up fax forwarding if you are going on a trip, but still want to receive your faxes while you are away. There are three fax forwarding settings:
  • Off (default)
  • Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
  • Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
  1. On the control panel, press Fax.
  2. Press Options until Fax Forward appears, and then press Select.
  3. Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
  4. Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
Dec 16, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    Placing a Forward Button on 1616 IP Phone
    What you need to do is, set up a button that will turn forwarding on. then set a number in manager on the forwarding tab, set the number. If the number is going to change a lot, then you should set a second button up as, forward number. One changes or sets the number, and the other toggles forwarding on and off
    Sep 04, 2009 | Avaya Computers & Internet
    Fax forwarding
    Function 7 set
    54 set
    1 for invalid set
    stop
    Sep 02, 2008 | Office Equipment & Supplies
    Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
    135 people viewed this question
    Top Vtech Lands Phones Experts
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
