Question about Hunter Dryers
Hunter fan model #28642 just stopped working. No fan, no light with the remote. Had this installed by licensed electrician just a few months ago and worked fine then just stopped suddenly.
Have replaced battery in remote. have reprogrammed remote. Have reprogrammed remote from another room to work with this fan and still nothing. been on hold with Hunter Fans forever. Anyone else had this problem?
    Genius:
  • Hunter Master
  • 1,617 Answers
You probably need a new receiver.
Posted on Jan 01, 2014
  • 10865 Answers
SOURCE: How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Posted on Jul 31, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: Hunter Fan has stopped accepting remote control signals
I'll guess and say that the fan quit working properly shortly after either a power surge in your house of after a light burnt out after turning them on. It has happened several times to the two Hunter fans we have here, both with the wireless remote control. After having both replaced under warranty, and then paying for a replacement, I finally took the receiver apart and found the root cause. There is a power regulator (looks like a power transistor) that uses the aluminum portion on the housing as a heat sink. The part is easy to replace for those of you who are handy with a soldering pencil. For those of you who are not, I'm sure you know of someone who is. Now for the good and bad news. The good news? The replacement part is about a dollar from an electronics supply house called Mouser. I tried Radio Shack, but they have really cut back on electronic components. The bad news? I can't remember the part number. I have a spare one, but I can't find it right now. I will look for it and if need be, I'll open up the receiver and get the number off of it and post back to this thread. After replacing the part in both a little over six months ago, we have had no problems with the receivers. Voltage spikes no longer take out the regulator.
Posted on Jan 04, 2010
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Hunter Regalia model 28642 light switch does not work.
Did you confirm switch is non-working? Possible bad connection between switch and light or switch & feed. Does remote work?
Apr 08, 2017 | Miscellaneous
Hunter fans light kit
I have the same fans...love 'em.. this should be a plug up type connection...? ... If you have to "twist wires"...stop and.call your electrician friend to help..there is obviously something different about the one...
.... sometimes the remotes do funny things...make sure you have the fan and remote settings matching...
... on mine, when the power blips off and on.. they fans either go to high speed or quit.. and all the light cut on high..
http://www.hunterfan.com/support
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
May 04, 2017 | Hunter Dryers
Need installation instructions for a Hunter Regalia ceiling fan, model 28642, item 183013, as the fan came without any. Am ready to install now!
Robin - Here's a link to the Owners Manual for the Model Number Hunter Ceiling Fan, you listed.
You may download and print it for future reference.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/45065.pdf
Please don't forget to leave me a rating for helping you. Thanks!
Apr 14, 2011 | Hunter Heating & Cooling
Just installed a hunter 27227 remote for use with my Hampton Bay fan. The fan was electronically reversable via a F/R switch on the old remote. Everything is working great except that the thing is running...
I recently had Hampton Bay fans installed with the Hunter remote and the electrician showed me that there is a small switch on the fan and you turn it either up or down depending on whether it's hotter months or cooler months because it changes the direction of the airflow to cool down a space or help spread heat. That may be what your issue is-- it's probably set to help spread heat rather than cool things down. I hope this helps!
Apr 19, 2010 | Hunter 27185 Remote Control
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Aug 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
About two years ago, I purchased a: Hunter 56 In. Brushed Nickel Ergonomic™ Remote Control Ceiling Fan Model 21871 A few months ago, a bolt of lightning struck through my house and my fan...
To have a contractor in your area look at this unit, try using the contractor search on the home page of fixYa, or simply use the yellow pages for your area.
My guess is that the lighting burnt or damaged the motor windings in the fan. I am sure that replacing the motor would solve this issue. I do not know where to find one though. I hope this helps some.
Jul 03, 2008 | Hunter Heating & Cooling
Dryers Logo
391 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
