Question about Water Heaters
I need an english manual for junkers zwr 18-3ke
I get the number 99 coming up when i try to switch the junkers on what does it mean
Can i get a manual on a bosch gruppe water heater
Having problem finding one. Is there a model #?
Also what are you trying to find out? as sometime googling the problem finds a solution faster than googling manual.
Nov 25, 2015 | Bosch Water Heaters
Looking for manual for Junkers gas geyser 250 KV3 P3152500TAI
they all work the same
http://www.americanwaterheater.com/support/manuals/res-gas.pdf
Nov 08, 2014 | Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers WR11 Water Heater Keeps Switching Off
Do NOT disconnect anything. Has the unit been maintained, cleaned and serviced? There may be a limit switch malfunctioning. Your safest bet is to have it checked out my someone who knows and is familiar with the unit you have, could be simple, but be safe and have it looked at.
May 27, 2014 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Junkers gas water heater automatic ignition not working
Yes that is going to be the contoll valve on that heater. You can probley fix it very easy with the right part. You will need to locate a plumbing supply over there in the UK. Give them the make and model number and tell them you need a unitroll gas valve for it.
Feb 08, 2009 | Water Heaters
Water Heaters Logo
78 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
