Question about Maytag Neptune MAH5500B Front Load Washer
I need to switch the doors on my Magtag Neptune washer and dryer.
Model MDG3000AWA. I want the doors to open in opposite directions.
    Champion:
  • 219 Answers
U just have to take the screws out and flip everything around
Posted on May 21, 2009
Hi I have a Maytag Neptune gas dryer model mdg3000awa.
i need more info about your maytag neptune dryer is there any issues you are facing with this dryer model?
Feb 22, 2017 | Maytag Dryers
Maytag Neptune MDE6800AYW shows error DO (Door Open?) bu the door is closed and the machine would not turn on
door switch, it is located inside the dryers front panel, there are a total of eight screws to take the front panel off, hinges have four and lift up an out, the other four are on the opposite side there are white plastic fillers(this is for door reversal), the panel lifts up and out. Here is a website to check the switch, may have a broken keepers,loose/broken wire or just a bad switch. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Maytag Neptune MDE6800 Electric Dryer
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
How do you take the caSE OFF OF A MAytag Neptune model MSD5500aww dryer to check burner
Open the door, remove the screws holding the hinges, then the door. Then remove the screws on the opposite side of the door opening, the front panel will then come off.
Feb 04, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I looked for door switch kit and some descriptions say for stacking...i don't need that and have duet model 9200 in white. want both doors to open in opposite diections. do i need to buy kits?
ummm.. you can only reverse the door opening in oyour dryer, your washer CANNOT be switched it only opens to the left. the dryer can be switched and the "hine kit" if applicable, only contains a new peicw of trim to cover the exposed trim after revesing the door( the catches are on top and bottom no need to reverse them)
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Need to install LP converion kit How do I get to the inside of dryer
To convert a gas dryer to lpg. Undo door hinge screws, lift door and hinges, door should come off. opposite side of door opening remove 2 screws opposite form door hing side. Now the front panel will pull off front the top. Ease the top out and the bottom is just sat in two hooks and will lift out. Now your are in.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
