Carrier Air v roof mount a/c, the condensor that's enclosed in the plastic inner shroud pulls so much moisture out of the air the fan blows it against the inner plastic cover and leaks into the camper. Had a tech come out and check amps and drain holes and said there's no way to stop it.
I had it level then changed it 20 about 10 degrees towrds the back trying to see if would drain away from the condensor
Did he check the pitch of the unit ?
