Question about Saws
Motor on my saw won't start
10" model 351.221140 saw. Motor will not start. Tried different outlet that powers other equipment. Pushed reset button, no luck.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Try looking at the stop start sw. sounds like a wire off or maybe a reset on the motor itself.
Posted on Jan 13, 2014
rowdy45176
  • 2176 Answers
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
Posted on Jan 19, 2009
  • 205 Answers
SOURCE: I have a Skil 10'' table saw that will not power on.
If your switch is in the base of the machine, like some portable table saws. The switch may be full of saw dust. I hade one that the reset switch couldn't be pushed to reset because the housing was packet with saw dust. I simply opened the cover and vacuumed it out. If you open your switch box up and it is clean inside, your switch is probably bad. You can check it by taking the two wires off your switch (with the saw unplugged of course) and taping them together, if the saw works when you plug it back in, get a new switch.DON'T use your saw wired this way.
Posted on Mar 28, 2009
  • 59 Answers
SOURCE: My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Posted on Apr 25, 2009
  • 33 Answers
SOURCE: Skil saw motor runs but blade won't spin
The key could be sheared in the final drive shaft as well.
Posted on Jul 25, 2009
SOURCE: My Powermatic 66 table saw won't start.
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Posted on Jul 29, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
My mastercraft 10" table saw
Reset button on the motor?
Aug 27, 2011 | Saws
Brand new saw trips 20 amp breaker every time I turn on the saw. It starts to turn and after about a second the breaker trips. Have tried different plugs on a different breaker. Still it will not start....
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Jun 30, 2011 | Dewalt DW744XRS 10-inch Job Site Table Saw...
Grizzly go691 10" table saw.
Make sure the motor is not bound-up by turning the shaft somewhat. Suspect a faulty power switch for the motor, also check for a thermal breaker on the motor--push to reset. It is not likely that the motor windings could have gone bad. Does the motor 'hum' when turned on? A start capacitor could have failed in that case. Contact the selling dealer for warranty help if you can't get it running again. Hope this helps!
Nov 19, 2010 | Garden
While cutting a piece of scrap plywood on my Craftsman 10" table saw, I accidentally cut through a bolt and it caused my saw to shut off. I pushed the reset button several times, but it doesn't feel as...
First off the saw will have to cool down and then the reset button will take some major force to reset. You should hear a distinct click when it does...
heatman101
Sep 20, 2010 | Craftsman 10" Table Saw
Table saw does not start.
if it just hummmms then check for a start capacitor on the motor body,if none,then check for a bad centrifigual motor switch on the end of the motor
May 14, 2010 | Craftsman 10" Table Saw
Mar 26, 2009 | Saws
Saws Logo
103 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
