Question about Cameras
Have a 20 month Optio E 40, today tried to switch on, lens woundnt come out, used the manual and switched on while holding arrow button, Playback piture showed in display, pressed half shutter to switch back and error message Lens error 113,0,0,0 appeared, Pentax want £80.00 minimum to look at it, can you help please\regards Terry
  • Terry Woodward May 19, 2009
    Sandy Tried a gentle fix 6, slight tap with the palm of my hand, (once was enough) All now operational Many Thanks
    Sniper:
  • 59 Answers
Try to take out the battery and put it back in.
Posted on May 19, 2009
    Sergeant:
    Champion:
  • 219 Answers
Hi, Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
or You should replace the lense barrel. Check out e-bay. There are repair services there that are cheap and helpfull.
Thanks! Sandy
I have a Pentax Optio E40 and get the message that the built in memory is full. How can I see what is in that memory? Can I delete those pictures to clear the memory?
Yes you can play back the images and/or delete them from the internal memory from the camera. I strongly recommend an SD card in the future. The internal memory can hold a maximum of about 87 pictures at the lowest resolution (2 pictures at the highest resolution). It'll be easiest to view the current pictures without an SD card in place.
To view the pictures, press the playback button (above and to the left of the 4-way arrow buttons) on the back of the camera. Use the left/right buttons in that 4-way area to navigate through the pictures. (You'll start at the last photo.) If you want to start the camera in playback mode, just press and hold the playback button while you turn on the camera.
To delete the picture that you are looking at, press the green/trash button to the right of the Menu button. Then press the up/down arrows to reach Delete and click OK (in the center of the 4-way buttons). (See Page 100 (page 102) of the manual.)
If you press the green button twice, you'll get a prompt to Delete all. That is similarly navigated with the up/down arrows and then OK.
Ricoh owns the Pentax Optio Line and has the manuals here: http://www.us.ricoh-imaging.com/support/download-details/356 . (You'll need Adobe Reader to access the program.) The user manual is the second link.
I hope this helps.
Jul 28, 2014 | Pentax Optio Cameras
Can I put pics from my internal memory onto a memory card? Or how do I download to the computer from the internal memory?
You can copy pictures from the internal memory to the memory card by using the Copy command in the Playback menu. Press the MENU button in playback mode. Use cursor-up/down to select "Copy image/sound" and press cursor-right. Select the camera-icon-right-arrow-"SD" and press the OK button.
Full details are in the "Copying Files" section of the manual (page 105 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://www.pentaximaging.com/files/manual/OptioS40%20Web.pdf
Jul 22, 2011 | Pentax Optio S40 Digital Camera
My camera is in a foreign language- need to change back to English
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the arrows to select a language. Press the FUNC/SET button.
Nov 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do i remove the green mode from my pentax e40
If you press the green button again it cancels green mode.
If you want to select a different mode press the down arrow on the four way controller when you are in capture mode.
That has icons for different modes like landscape or program mode.
Move to the icon you want by using the 4 way controller then press ok.
The button with a triangle on it that is above the 4 way controller switches between playback and capture modes.
Jan 30, 2010 | Pentax Optio E40 Digital Camera
No date print on photo
This is how to print the photo with the date on.
Go to the playback mode and choose the photo to print.
Press the down arrow on controller.
The mode palette appears.
Use the controller to select DPOF.
Press the OK button.
Use the up/down arrows to select number of copies.
USE THE GREEN BUTTON TO SELECT DATE PRINT ON OR OFF!
Press the OK button to print.
Hope this helps, it is well hidden!
Jan 07, 2010 | Pentax Optio S6 Digital Camera
While taking photos today during a football game, after about 20 shots, my camera continued what seemed to be regular picture taking, but when I checked the shots in playback mode, the screen is blank! Any...
the shutter most be out or the mirror most be out of timing. if the shutter is bad then it will cost around 180 but try this first turn on the camera take the lens off and hold the mirror with your finger up and press the release switch it should click twice then put on the lens and shoot hopefully it will fix it if it didn't its the shutter
Sep 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
Symbol of a lock
I had the same problem - try this. Switch to playback mode by hitting the play button. In playback mode try the menu button (It worked for me). In the settings scroll down to the reset option and reset all camera settings.
Hope this works for you
Dec 11, 2007 | Pentax Optio S5i Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
