Question about Electrolux Dryers
EIGD55HIWO get error code E66
What is the ltf7000es0 error code E66
Hello friend, thank you for your post!
I understand that your Frigidaire washer is displaying an error code of "E66". An "E66" code stands for heating element relay failure. This could be a problem with your heating element or control panel. In order to properly locate the issue you would need to disassemble your washer and test each electrical component to assure it is providing an accurate reading. This is not a simple DIY job. I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
May 05, 2015 | Frigidaire Affinity ATF7000E Front Load...
WHAT DOES THE E66 MEAN ON MY AFFINITY DRYER
Good Morning Friend, this is Z, Thank you for your inquiry!
An error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code on your Frigidaire dryer. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
May 21, 2014 | Frigidaire AEQ7000ES Dryer
Frigidaire FASG7073LW0 error "E66 HEATER" then "DOOR OPEN"
Hello Abe D - An error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Jun 22, 2013 | Frigidaire Dryers
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
My washer stopped in mid cycle. I unplugged it for 5 minutes hoping for a reset but no fix. I then cut the circuit breaker for 5 minutes, still no reset. The error code is E66 Model is 2940E0
E66 error is for "heating element relay failure". You need to replace the "water inlet valve". If you can post the model number off of the machine I can direct you to the part you will need.
Dec 14, 2010 | Frigidaire Washing Machines
I have forgot the Lock-Code from My Nokia E66 !!! Please help me! I need the Mastercode...my Nokia E66 is fully locked!!! IMEI: 352942022719907 THANK YOU VERY MUCH FOR EVERY HELP!!!!!
I have forgot the Lock-Code from My Nokia E66 !!! Please help me! I need the Mastercode...my Nokia E66 is fully locked!!! IMEI: 35796033026071 THANK YOU VERY MUCH FOR EVERY HELP!!!!!
Nov 09, 2010 | Nokia E66 Smartphone
I have forgotten the lock code of my e66. now when i restarted the phone it asks me for lock code. can some one help
Nokia E66 I forgot password. When I restarting asking lock code.
How do I get password
Aug 06, 2009 | Nokia E66 Smartphone
Dryers Logo
21 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
