CF error code appears on my Hitachi Washing Machine Model NW-D8AX(H) and it does not Starts
IT DOES NOT STARTS AND BEEPBEEP ONLY
4 Suggested Answers
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Tip
Who made your Sears Kenmore Range, Stove, or Oven?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Sears does not make any of its own appliances. They have different manufacturer’s make them for them. To see who actually made the appliance you can check out the model number of your appliance and then look to see who made it.
The first three digits of the model number refer to the manufacturer.
- Roper made appliances starting with these numbers
103
647
835
911
155
-Whirlpool made appliances starting with these numbers
106
110
562
665
198
-Caloric made these
174
960
-Kelvinator made these
417
662
628
-Gibson starts with 253
-D&M starts with 587
-GE made these
363
362
-Speed Queen starts with 651
-Maytag starts with 925
-Litton starts with 747
-Toshiba starts with 562
-Fedders starts with 484
-Amana starts with 596
-WCI starts with 790
-Tappan starts with 791
-Jenn Air starts with 629
This will give you an idea as to who made an appliance. By simply checking the model number and comparing it to this list you can see who made it.
on Mar 08, 2010 | Ovens
I have an error code 2h and I cannot change any settings
Similar to previous washing machine question. Is the delay start activated?? Is the machine waiting for 2 hours before it starts??
Jan 03, 2015 | Washing Machines
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Our playstation hard drive is corrupted. what should i do
Well if your using the older model of PS3's (FAT ones) what you can do to attempt to fix it is power off your ps3. Press and hold the power button, you'll here a beep. keep holding until you hear two beeps quickly( e.g. beepbeep) one you hear that, let go of the power button. If done correctly you will see a screen that has some options on it. The option you want is Restore File System. If that does not fix it, and continue's to tell you that the Hard Drive is corrupted, then you need to buy a new hard drive unfortunately.
I've placed a Video here for you that might help visually and also with the "beep" timing.
Apr 18, 2011 | Sony PlayStation 3 40GB System
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
