Question about SimpleTech SimpleDrive Turbo USB 2.0 3.5" External (Black/Gray) Hard Drive
The Power supply to my back up has been lost, what voltage/amperage does it require?
    Champion:
  • 411 Answers
12v DC 2.5A
Posted on Jan 07, 2014
2 Suggested Answers
  • 261 Answers
SOURCE: What is the Power Supply voltage output?
hi5 volt
Posted on Feb 16, 2012
I lost the Power supply for a Bell Vista 200
If you have several other Vista 200s (like in an office) you may get the specific voltage\amperage\and connector design from another power adapter. If you have that info there are many retail electronic stores that sell universal power adapters that may fit your needs. The owners manual may also designate the required voltage\current.
Aug 26, 2016 | Power Computers & Internet
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
42" magnavox lost picture but
Power supply problem. If you have electronic experience pull the rear of the panel and look at the power supply and check for bulged or leaking or busted caps replace them and i will probably be good to go. if you cant do component level repair order the whole board and also dont kill yourself - tv voltages and amperages are strong enough to kill a human.
thanks,
Michael
Feb 07, 2011 | Televison & Video
Battery lasts only approx ten minutes. If the battery holds a lot more power than it supplies, it is certainly not supplying it. Without the net power supply this machine is less than useless.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
Sep 23, 2010 | Acer Computers & Internet
What power supply is required for the Bafo 700 7 port usb hub ?
Probably the one it came with?
Anyway, if there are details about voltage and amperage on the back of it you could buy an aftermarket switching powersupply.
The voltage output of the powersupply has to be within 5-10% of what the hub needs, but the amperage can be equal or higher. (anyone who disagrees with this is wrong)
May 26, 2010 | BafoTech BAFO (BF-700) Networking Hub
Hi, i'm trying to find which power supply this runs from
it should tell you next to the power input port, along with the pin configuration (centre pin + or -) and the required amperage.
Feb 28, 2010 | Archos DEX-CDRW CD-RW Burner
What voltage and amperage the western digital wd25001032-001 will work. I lost the original power supply and need replacement.
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Feb 21, 2010 | Western Digital 250GB MyBook External USB...
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Supply voltage issue...
the x1650 card requires extra amperage, not extra voltage. It runs on the same 12 volts as the rest of the computer. The issue is that if you have an underpowered power supply, of if you have a lot of other devices hooked up, you may need a better power supply to provide enough wattage to the card. As long as you have at least a 400w power supply, I would expect you to be alright.
Feb 13, 2008 | ATI RADEON X1650 Graphic Card
SimpleTech SimpleDrive Turbo USB 2.0 3.5" External (Black/Gray) Hard Drive Logo
62 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
