Question about Universal AULA Ogre Soul Professional Optical Gaming Mouse - Black 138cm-cable
I just set up my aula broken soul behead keybord and mouse set but my mouse the ogre soul does not move my actuall mouse on my screen it scrolls clicks and whatever but it does not move Help
Scroll wheel stopped working. It feels weird now when i try to scroll it. How do i fix it?
Disconnect the mouse from the computer and turn it upside down. The screws to disassemble the mouse are under the pads on the bottom of the mouse. When you disassemble the mouse, you will find that the scroll wheel axle is gummed up, and the interruptor wheel is probably dirty. Use an old tooth brush and alcohol to clean the scroll wheel components, and let the components dry. You can use glue to re-attach the pads after you have reassembled the mouse.
Sep 05, 2015 | Universal AULA Ogre Soul Professional...
My toshiba touchpad doesnt move the mouse, it scrolls up and down on things
check the mouse settings in the control panel, these functions may be locked out or their may be a fault in the driver software.
Sep 01, 2014 | Toshiba Computers & Internet
I cannot find a driver for my ogre soul optical gaming mouse ive looked everywhere but cannot find a driver for it windows wont update the driver automatically please help
Is the mouse on windows HCL? Can you check if someone has writen a driver for it? You cant be the only one that has this problem. I know you have windows but on the linux side of things, people often can write drivers for their unsupported hardware.
May 29, 2014 | Universal AULA Ogre Soul Professional...
I need a game manual for shining soul 2. i lost mine and i have forgotten how to use my summons
Shining Soul 2
FIELD CONTROLS
Control Pad Move character
A Button Confirm/Talk/Pick up/Attack. Charge Attack (hold). Shining Force (hold).
B Button Cancel/Use items/Throw (hold)
L Button Display & select ARM equipment
R Button Display & select ITEM equipment
Start/Pause Display Camp Menu. SELECT = Use equipped Soul
CAMP CONTROLS
Control Pad Move cursor
A Button Confirm
B Button Cancel
L Button Select ARM equipment (Item Screen)
R Button Select ITEM equipment (Item Screen)
Start/Pause SELECT = Scroll through item descriptions
Mar 10, 2011 | Video Game Consoles & Games
Sansung Soul, working, broken screen.
did you dropped the phone? if not i think there is a problem on it, you need to send it in for service.
Jul 02, 2009 | Samsung U900 Soul Cellular Phone
Imprecise scrolling
go to control center, mouse properties, use the wheel-tab, and set lines to scroll to 1.
Jun 03, 2009 | Logitech Cordless Mouse
Maxdata keyboard suddenly does not work after two years.  Only the touch pad works
sounds like your keyboard connector has come loose, these eyboard units are actually a seperate keyboard and mouse pad built into one unit, so the mouse's electronics are seperate,
you may also want to check the connector to see if there are any broken/bent pins in the connector (sometimes happens, when accidently unplugged)
hope this helps :)
Oct 06, 2008 | Maxdata iStarUSA TC-A100B 1U IPC Keyboard...
Wheel will not do just a standard scroll
You should make sure that you have the LX7 Setpoint software installed to set the features you want. For the scroll button or button three if pressed, I have mine set to zoom (first selection). The scroll function of the wheel should be automatic. Go the mouse movement settings and set the scroll size to 6 lines. That should allow you to scroll your pages adequately. If this helps send a reply for others to view.
Aug 20, 2008 | Logitech LX7 Cordless Optical Mouse
Universal AULA Ogre Soul Professional Optical Gaming Mouse - Black 138cm-cable Logo
158 people viewed this question
Top Universal Computers & Internet Experts
Dan Shibata
Dan Shibata
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Are you an Universal Computer and Internet Expert? Answer questions, earn points and help others
