Hi our canon image runner 1025N is saying empty waste toner! We are in Haiti - so any advice for a do-it-yourself would be most appreciated!!!
  • 1,294 Answers
The waste toner box is located under the OPC drum.Remove the imagine unit and in left part a black box is a wastw tonwr box.Pull out the plastic obturator and pull out the toner.
Posted on Dec 30, 2013
  • 47 Answers
SOURCE: Replacing waste toner container
it is behind a panel in the lower left corner of the left side panel. Just pull the panel off (1 screw I think, maybe 2)pull out the bottle and carefully dump it into a plastic bag. Make sure you clean inside the neck of the bottle with a towel or rag otherwise the sensor will still think it is full.
Posted on Jun 12, 2008
MXM450
  • 62 Answers
SOURCE: locating waste toner bottle canon image runner 1300
the waste toner is the unit where the drum is attached to. it actually has a hole to clear it up but i recommend you to remove the drum, the charger roller, the cleaning blade and carefully vaccum the unit. you gotta vaccum the corners, gears, everything. then put the piece together and give it a try. if it doesnt work go to your closest canon retailer an buy a new drum unit: GPR-10 Drum Unit.
Posted on Jan 24, 2009
  • 59 Answers
SOURCE: Changing Waste Toner in CANON IR3245I
Open up the toner cover, undo the screw.
Then on the flat surface under the paper delivery tray there is a round cutout , remove this little cover to reveal a screw, undo this and slide the front cover off to the left. The waste toner bottle is now visible.
Posted on Apr 01, 2009
  • 67 Answers
SOURCE: waste toner
Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
Posted on Apr 10, 2009
  • 153 Answers
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
Posted on Jun 01, 2009
IR 5065. Where is waste toner receptacle located?
You must empty the toner box and with soft clothes try to clean all the sensor window on used toner box and put it again.
Mar 03, 2016 | Canon Image Runner Toner Black...
Cannon IR 33201 error e000019-0000
this is error for waste toner, and the waste toner needs to be cleaned.
On left sideway of copier, in lower left corner you will see the plastic cover with one screw.
Remove the plastic cover and remove waste toner box by pulling toward you. Empty it and clean the neck of the bottle. Put it back in and restart copier,
Hope that helps!
Aug 18, 2011 | Canon Image Runner 3320I Copier
Problem is waste toner removal or replacement indicator is displayed.
The waste is collected in the drum unit. 99 percent of the time you cannot recover by trying to empty. 8 years working on canons here. Best to replace the drum unit now!
Dec 22, 2010 | Canon Image Runner 1630 Copier Copier
How do I empty the waste toner container?
1- Open The Front door,2- disengage developer unit (DP),3- down the feeder using green handle,4- remove screw of drum unit,5- pull out the drum unit6- empty the waste toner removing with white strip.
Sep 23, 2010 | Canon Image Runner 3320I Copier
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
Waste toner
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Waste toner
Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
jasbo
jasbo
