Question about Yamaha BD-S1065BL Blu-Ray Disc Player
BD-S673 freeze when I watch a movie freeze suddenly
How do I unlock all DVD region playback on Yamaha BD - S673.
Hi Leena,
Did you get an answer to your request (I have the same one).
Dec 30, 2014 | Yamaha BD-S673 3D Blu-ray Player
Tip
Watch 1080p Blu-ray DVD Movies to Xoom/Acer A500/Galaxy Tab in Full HD
Watch 1080p movies on tablets like Motorola Xoom/Acer A500/Galaxy Tab <br /><br />Tablet PCs like Samsung Galaxy Tab 10.1, Motorola Xoom and Acer Iconia Tab A500 support 1080p display. Even though the devices are from different brand, there is one common feature for these tables, i.e. Android OS. So no matter you have Blu-ray disc movies, DVD movies in VOB format, or MKV videos, you can enjoy the HD quality. <br /><br />However, before putting the videos to your Galaxy Tab, Xoom or A500, you should convert them to the Android supported formats. Aunsoft Blu-ray Video Converter Ultimate is the best choice for you to put and play <b><a href="http://canon-videoconverter.com/2011/06/watch-1080p-blu-ray-dvd-movies-to-xoomacer-a500galaxy-tab-in-full-hd/">1080p BD DVD movies to Xoom/Acer A500/Galaxy Tab</a></b>. It does not only enable you to load videos from Blu-ray disc or DVD disc, but also import .mkv, .tivo, .vob for conversion. <br /><br />Follow the simple steps below and you transfer the output files to tablet PCs. <br /><br /><b>Step 1. Import videos to Aunsoft Blu-ray Video Converter Ultimate.</b> <br />Run Aunsoft Blu-ray Video Converter Ultimate as the <b><a href="http://www.aunsoft.com/blu-ray-video-converter-ultimate/">BD/DVD movies to tablet converter</a></b>. For movies from disc, just insert the disc to BD/DVD ROM, and click the "Load BD/DVD" button to import movies directly. For movies from hard drive, click the "Add" button to browse videos. <br /><br /><b>Step 2. Choose MP4 format for tablets.</b> <br />Click the Format option, and choose HD Video &gt; H.264 HD Video(*.mp4) as output format. There are also profiles for Android, but in different resolution. We use 1080p here. <br /><img src="1080-video-xoom-galaxy-acer.jpg" /> <br /><br /><b>Step 3. Choose subtitle for Blu-ray or DVD movies. (optional)</b> <br />For each main movie or main title from BD/DVD, you can choose the subtitle language according to your preference. You can also check the box for "Only show forced subtitles". <br /><br /><b>Step 4. Convert videos to 1080p for full HD.</b> <br />Click the convert button under the preview window, and the conversion from BD/DVD to A500/XOOM will start immediately. <br /><br />After the files are done, just sync and transfer the videos to your tablet. And then you can <b><a href="http://www.aunsoft.com/blu-ray-video-converter-ultimate/">watch 1080p videos on Acer A500</a></b>/Motorola Xoom/Galaxy Tab in the car. Freely enjoy the movies on the go.
on Jun 17, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to watch Blu-ray movie on your HDTV
Blu-ray movies always provide people with outstanding visual and aural experiences, so you can imagine how wonderful it is to watch BD movies on your widescreen HDTV with your families sitting on the couch comfortably in your living room. Roughly, the ways people used to watching Blu-ray movies are various, and the straightest method is connecting a Blu-ray disc player to a HDTV for playback. However, People also have other solutions even though they have no Blu-ray player, including using an Iomega hard disk media player or a WDTV Media player, Popcorn Hour, Xbox 360, or other media players or devices as a medium, or using an external hard drive to store the BD files and then connect it to HDTV to watch the movies, or using the HDMI port or an S-Video cable to watch videos from PC to HDTV, etc.
Since Blu-ray movies have strict copy protections (AACS, BD+, region code), as well as these intermediates have their requested video formats, for example, some supports mpeg4, divx, and xvid, some supports AVI or WMV, and some supports MKV or others. It is essential to remove BD protections and rip Blu-ray to an appropriate format for playback on HDTV through these in-between devices. You may ask: "what is your method to do format conversion?" Well, the following paragraphs will shed some light on this question.
Software you will need:
Pavtube Blu-Ray Ripper
To find a step-by-step instruction in the following:
Step 1: Install and launch this program, and afterwards you can click "DVD Rom", "DVD Folder" or "IFO/ISO" icon to load your Blu-ray files.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle", then all the subtitles in the BD movie will be listed out, including language and subtitle ID, you can select one according to your own needs.
Click the drop-down list of "Audio", and then all the info about audio tracks are shown clearly, including language, audio codec(turehd and dts master audio are both supported as well), stream ID, and audio channel, you can choose whatever you like to do conversion.
Step 3: Select output format
Click on the drop down menu of "Format" to select output format. Which one to choose is depending on the compatible formats of your media players or devices that you used to transfer BD files to your HDTV. For instance, if your player is capable of playback .m2ts files, you can choose "Copy"- "Directly Copy", and this option will keep the original quality of your BD content to full extent. If your device allows HD playback, and supports h.264 mp4 format, and then this one would be the correct selection for you. The rest can be done in the same manner.
Directly Copy:
H.264 HD Video .mp4:
Step 4: Set advanced settings
Please notice that this step is unavailable if you have chosen "Directly Copy" in Step 3. Click on "Settings" button, and then you will be able to adjust audio and video parameters including codec, aspect ratio, bit rate, frame rate, sample rate, and audio channels in the popup window as below. 5.1 channels are supported to keep the stunning surround sound of the BD movie.
Step 5: Click "Convert" button to start BD ripping
Once finished, the output files can be found out via clicking on "Open" button effortlessly, and then you can use your own ways to watch Blu-ray movies on your HDTV, such as connecting your PC to your HDTV via S-Video or HDMI cables, or adding them to your media players for playback on the HDTV, or whatever. Just Enjoy it.
For more: http://www.pavtube.com/blu-ray-ripper/
on Mar 11, 2010 | Audio Players & Recorders
Samsung bd-c6900 xaa dvd player freezes on 3d prometheus movie in same spot at scene 20
Report the error to Samsung support. There is an ongoing problem with the firmware. Make sure you have updated to the most recent firmware version 1025.0 that was released this month. There are still unresolved problems with the new firmware release though. Many movies will fail to load and other will load and play but will skip/freeze during playback. This is related to the anti-piracy features on the Blu-Ray that the player can not properly handle.
Mar 30, 2013 | Samsung BD-C6900 Blu-ray 3D Player
I can't watch dvd movies on my Samsung BD-P2550.
What happens when you attempt to watch a movie? Please advise. Thanks.
Mar 13, 2011 | Samsung BD-P2550 Blu-Ray Player
Placed the movie "Salt" in
Have you updated your Blu-ray player firmware this month from Samsung.com? It looks like the latest updated was from Dec. 1, 2010. I was having the same issue and downloading/installing the update resolved the issue...I'm watching the movie now but before the update I was having the same issue you reported. After the update the disc still seemed to pause on the loading bar but it worked. Check out http://www.samsung.com/us/support/downloads/BD-P2500
Dec 25, 2010 | Samsung BD-P2500 Blu-Ray Player
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
Problem with Wall-e Blue Ray movie
i would say the problems comes from the way the company formatted the movie onto the blu ray discs. and i would say that there will most likely be a recall on them. if anything connect the manufacturer of the movie. hope this helps you.
Dec 17, 2008 | Samsung BD-P1400 Blu-Ray Player
Blu ray movie freeze up
I had the exact same problem. I found an old post somewhere that said turning off an internet connection might do the trick. So far it has done the trick for me, but I only tested on one movie. I was getting a freeze every 10 minutes. After turning off the network connection ( wireless in my case but same should apply to wired ) I had no freezes. I'm not sure if I see a pattern but I'm guessing that BD Live may be the culprit and perhaps discs without it suffer because of some bug in the PS3 software to connect or something. Just a wild guess. Looking at updates, BD Live came in on firmware update 2.2 in 3/08. I probably only upgraded recently from a much older version so there is some likelihood to this being the culprit. Don't have enough discs with BD Live to test.
Dec 14, 2008 | Sony Blu-ray Remote for PlayStation 3
Yamaha BD-S1065BL Blu-Ray Disc Player Logo
41 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
