Question about Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
I have a Jenn-Air side-by-side refrigerator with ice maker, model: JSD2789DEB. The ice maker recently stopped working and when the ice maker arm is up, it leaks water underneath. There is no water/ice inside the refrigerator so the drain is not a problem. There is no water in the ice cube maker assembly either. Any ideas?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Posted on Dec 30, 2013
  • 1 more comment
  • Ketsuda Abramowicz
    Ketsuda Abramowicz Jan 13, 2014
    Sorry, I totally mis-wrote that. The leak only happens when the arm is down. Also, whether the arm is up or down, water will still come out of the water dispenser in the freezer and does not cause leaking.
    That last sentence should have said "using the water dispenser does not cause leaking."
  • RJ Systems (Retired) Jan 21, 2014
    The water line to the refrigerator is normally only 1/4 inch. with the water dispenser open the pressure would drop off at the valve inlet. I still think the valve inlet is where your leak is at. Especially because it stops when using the water dispenser. No water being fed to the tray, I think is a separate problem. Mineral build up in those valves is a common problem and your line to the ice maker may be plugged as well as the leak. There are some really good techs. here. If anyone here would like to add an opinion for Ketsuda, I would never be insulted trouble shooting a problem. Please feel free to jump in. Check that water valve Ketsuda, I think you will find the inlet leaking and a problem on the outlet to the tray. I would check the valve over if I were there. Hope this helps! Let me know what you find. ---------Roger.
SOURCE: Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Posted on Jan 03, 2008
  • 27 Answers
SOURCE: Jenn Air Side by Side Refridgerator
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Posted on Feb 24, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
tech master
  • 120 Answers
SOURCE: Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Posted on Oct 17, 2008
SOURCE: jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Posted on Nov 24, 2008
We have a Jenn Air Side-by-Side. Water dispenses without problem, but the ice maker has stopped making ice. Now, when we try to produce ice (by lowering the ice arm), the ice hose pops free of the...
It sounds like the tube you speak of is frozen with ice, so it expanded the tube. Try unplugging the refrigerator and allow or help the ice in the tube to melt. You likely need a new hose, as when water freezes it expands and it likely expanded the hose, which is why it will not stay on securely. ( I don't know without seeing it, but this seems plausible to me)
Nov 03, 2017 | Jenn-Air JSD2695KES Side by Side...
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
