Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
Treadmill won't run - Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
Treadmill stops running after 10 mins,won't start for about an hour
LUBE the deck belt +rollers bearing. This happen because lack of lube and maintenance according with the s. maintenance
see the video
God bless you
Jan 11, 2013 | Reebok Exercise & Fitness
My fan won't work on my nordictrack 4400R treadmill. What should I do to get it working.
please test the voltage in the motor fan with DVOM. IF There are voltage , and the motor is NOT running , replace it.
However you must tight very well all the connectors. Test the fuse in the treadmill see the block diagrams attached for troubleshooting.
God bless you
Jan 09, 2013 | Exercise & Fitness
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
Dec 13, 2011 | Exercise & Fitness
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
19 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
