Question about Linksys Wrt54g Ver.6 Wireless-g 802.11g Broadband Router 4-port Switch Complete
Trying to find password for Lynksy WRT 54 G Ver 6
I need password
  • 7,993 Answers
If the router is yours (and you have physical access to it:you can touch it), use a straightened paper clip to press the RESET it. After reset use username admin, and password admin. If that does not work, leave the password blank.
Once you enter the web interface open the administration tab and change the password.
Note: I did not give you the url of the web interface for the router. You will have to find it in the user's manual.
Posted on Dec 31, 2013
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
My wireless router with ports works fine with hard wire connect. I can' t get my laptop to connect wireless. Reset unit and all. can u help Lynkys, wrt -G ver. 6 Used to work fine. Cisco, says by another...
It can be fixed most likely unless its just an old unit that has burnt out. Try reinstalling the software that came with it and rebooting your system. If that doesn't work search for discussion in wireless router discussion forums.
Nov 09, 2009 | Linksys Wireless-G WRT54G Router
Need to reset to factory default a linksys wrt 54
Push and hold the reset button in for like 1-2 minutes then release it, it should reset the settings to default
Oct 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How set up the Linksys WRT 54 g router with primus communication
hi,
login to admin page, go to WAN connection setting.
before that , please be ready your primus username and password.
after that save the changes.
Sep 11, 2009 | Linksys Wireless-G WRT54G Router
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
I have problems with installing Linksys wrt 54 gl wireless router
i will need more information to help you with this. but since this is a new router, you definitely have a modem, chances are you'll have to bridge the modem first for you to be able to use your linksys router
default username is blank
default password is admin
check with your ISP if your connection type is DHCP or PPPoE
if it's PPPoE, you'll need to configure your router, you need to put in your username and password for your ISP inside your router's GUI or main interface page
Jan 28, 2009 | Zyxel Prestige P-330W Wireless Router...
Router safety
log into your router (lynksy) there might not be a password. Then just go under "change password" in the menu.
Jun 27, 2008 | Linksys Wireless-G WRT54G Router
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Linksys Wrt54g Ver.6 Wireless-g 802.11g Broadband Router 4-port Switch Complete Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
