Question about Nespresso Coffee Makers & Espresso Machines
My magimix Citiz has one set of lights not working
2 Suggested Answers
  • 6 Answers
SOURCE: My Nespresso Magimix Citiz does
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
CitiZ swap outside casing
I've stripped the casing from this model and it isn't difficult, though you do have to be careful. You should check out the Service Manual for the machine to first to decide if you're up to the job. The service manual is readily available online, just Google, 'Nespresso Citiz Service Manual' and you should get it in PDF format. The manual explains the process for dismantling and re-assempling. It also conatins wiring diagrams for all versions. It looks like the casing is the same, regardless of country. When I stripped mine, I didn't have the specialist Nespresso tools for the job, but carefully inprovised using small pliers instead of the special oval screw driver. BEWARE...any remaining warranty will be invalid if you carry out any work on the units!
Jul 23, 2013 | Nespresso Citiz C110
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
The CLEAN light has come on. How do I clean it?
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
Have same problem with my Citiz & Milk, I wash out the aerocinno after each use and I have cleaned it out again snnce but still cna't get it to heat the milk. The machine is only a couple of months...
The last couple of times I have used my milk frother on my Nespresso Magimix has overflowed creating a mess. Its almost as though the pressure builds up and forces the milk to overflow. Any ideas?
Oct 18, 2010 | Nespresso Aeroccino Automatic Milk Frother
My magimix coffee nespresso machine has just been descaled but still has flashing lights - how can i stop the flasing lights
Thanks Tish3030! By far the most helpful answer! The manual did not help at all. Besides, I can get the manual anywhere on the internet. :p Removing the tray worked! Genius!
May 31, 2010 | Magimix L'Expresso Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
