Question about Emerson Televison & Video
Picture parts model number is ewf2703. I have a 27" emerson flat panel portable tv. when i turn it on there are horizontal lines across the screen. can i fix it myself without getting electrical shock?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Flat panels tv's use memory to paint picture on the screen. If the chips are bad, you'll see lines, checkers etc.
Posted on Mar 27, 2014
4 Suggested Answers
  • 1039 Answers
SOURCE: I have a horizontal line going across the picture of my tv.
The panel is bad and will need to be replaced.
Posted on Dec 06, 2009
  • 26 Answers
SOURCE: Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
Posted on Feb 11, 2010
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Posted on Oct 18, 2010
Ten year old emerson 27" flat-screen tv has multiple thin white horizontal lines and has audio
Backlight CCFL lamps fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | Emerson Televison & Video
Horizontal lines across screen of sony KDL-46BX450
Sounds like a T'Con fault itself. Re-seat all the incoming and outgoing flat cable wires to T'Con. If it do not help you, replace it with a new one of same part number. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Thin horizontal line across screen
Hello
You haven't specifed nothing about the model number or brand name of your flat panel teleivison. i assumes that it to be a picture tube based one and posts this solution before you.
A thin horizontal line across the screen with sound output is OK, is the sympton of total failure of vertical sweep. This may be due to failure of vertical output IC or loose solder terminals of that IC. The vertical output IC will heat up while working, and repeated heating and cooling may make its solder terminals to get loose. Just open your TV, pull out the board that contains vertcial output section, turn it upside down, resolder all the solder terminals of that IC by applying a little more solder, without making any solder bridge in between terminals. Check the voltage to the vertical output IC also. If this resoldering method does not help you, replace the vertical IC itself with same type and number will solve your TVs problem. OK.
May 07, 2011 | Televison & Video
Have horizontal lines across the screen and some
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Apr 28, 2010 | Sanyo Televison & Video
Line across screen no video just audio
Horizontal oscillator is toast.Must be repaired by a TV tech in shop
Mar 24, 2009 | Televison & Video
I have a 37in LCD Emerson tv and there is a division line in the tv. Top is normal bottom is dark. How do i fix it
sounds like a failed backlight or inverter.
larger LCD sets use multiple lamps horizontally across the screen.
Dec 03, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
