Question about Panasonic Televison & Video
Panasonic pt44lcx65 problem off stay turn on when i turn it on it turns off after a few seconds
  • 38 Answers
That is normal. Set goes through a cool down for about 5 minutes
Posted on Jan 01, 2014
MY TV HAD GREEN SPOTS AND THEN WENT BLANK. I REPLACED THE LAMP AND NOW WHEN I TURN IT ON THE POWER BUTTON BLINKS GREEN 3 TIMES AND THEN YELLOW 2 TIMES. THE SCREEN STAYS BLANK
The lamp will not fix the green spots. That is due to bad polarizers in the optic block. The lamp is only a white light. http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDF
According to the manual you are not getting enough airflow which would explain the optic block failure. Make sure the TV has lots of space for air around it and is not inside a cabinet that would overheat it.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
How to reset lamp timer for panasonic 61 in tv pt61lcx35
go to http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDFand download it it is in the owners manual
Good Luckor contact customer support at
1-888-VIEW PTV(843-9788) Good Luck
techman
May 07, 2010 | Panasonic Televison & Video
I replaced the bulb in my tv. pt44lcx65. everytime i turn on the tv it says i need to reset the bulb timer? how is this done? thank you.
Instructions should be with new lamp. Press and hold volume down on TV front while pressing PLAY, or SPLIT, or PIP on PAN TV remote aimed at little window on TV front near front panel buttons for 5 seconds. Message will appear on screen saying lamptime reset. Press end to exit.
May 02, 2010 | Panasonic PT-44LCX65 Television
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a PT44LCX65 panasonic. The tv runs for 4-5 minutes than shuts off. Also have had green spots around screen. called Pan. tech out and they refused to fix spots until T.v. is fixed to stay on....
Hi, thanks anyway. I downloaded the service manual read through most of it and ran through the tests and determined it was the ballast C.B.A. not to mention there was a code flashing which supported this conclusion.
Nov 30, 2009 | Panasonic Televison & Video
How do you reset a lamp hour meter in a panasonic TV
hold volume on TV (-) down and (0) zero on remote for five secs..
Jun 30, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Reset lamp meter panasonic pt44lcx65
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0". If not, try using the PIP button instead of the Split button. I have heard of a few sets using this sequence. Either way, the key is holding both buttons simulataneously for at least five seconds.
Rob
Dec 29, 2008 | Panasonic TY-LA1000 Projector Lamp for...
PT44LCX65 Has spots and Haze
Panasonic has a fix for this problem. No need to replace the light engine. Just have a service tech do an "eprom upgrade" - Fixed mine.
Jan 24, 2008 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
12 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
