Question about AT&T 1725 Answering Machine
My lucent 1725 appears locked up and the machine beeps and flashes "F2". I can't get it unstuck
2 Suggested Answers
  • 59 Answers
SOURCE: Lucent Technologies 1725 answering machine
Taken from the 1725's User Manual:
Deleting Messages
1 Connect with the answering
system.
2 To delete selected message
— Press
and release 3 while the message is
playing.
To delete all messages in a
mailbox
— After you have listened to
all messages and heard the two beeps,
press 3, and then the mailbox
number.
You can download a copy of the manual at the following URL:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=164
Posted on Sep 14, 2009
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
I can't find my manual. The power went out and when it came back on my machine now beeps incessantly and flashes an F2. Don't know what that stands for or how to stop the beeping. Unplugged and plugged...
Well I feel your pain. I have the same machine and we had a winter storm about 3 weeks ago and had a power outage too. When I went to reset my answering machine it shows a F0 code which I can't find out what it means either. I also have tried everything, nothing works, none of the buttons respond and all i get is the F0 error code and constant beeping. I am still trying desperately to find a cure for this. Like you I'm afraid the power surge fried something. The manual gave one number which is 1-800-222-3111, I called and they couldn't help me because this was an old discontinued model. Grrrr...
I can give you the web site to get a copy of your manual that you can print or read:
http://dl.owneriq.net/9/9480d395-d537-9fc4-a562-229da0743f36.pdf
If you find a cure for this please post it. I love this machine and think it is so much better than most of whats out there. I don't want to have to replace it but need to do something soon. Good luck, Barb
Feb 24, 2011 | AT&T 1725 Answering Machine
I have an answering machine AT&T 1715, but miss the cord power, could you please tell how many amps need and voltage too
Check the bottom of your answering machine. It should have the required power adapter listed. At least my answering machine had a nice clear label.
My 1337 AT&T answering machine uses the DAS-2 power adapter. This outputs 9V 780mA. Googling the adapter number I found that the Lucent 1715 also uses the DAS-2 adapter. (The Lucent is probably identical to the AT&T but check your machine.)
I found a used one here: http://cgi.ebay.com/LUCENT-TECHNOLOGIES-DAS-2-TELEPHONE-POWER-UNIT-9-VAC-/250730379907 . There may be other e-bay sellers with the item.
I hope this helps.
Dec 08, 2010 | AT&T 1725 Answering Machine
The oven starts to beep and flashes F2 when the
the f2 is telling you that the tempature is to high. It could be your control board. I personely would call a tech as its got to do with the contacts on the control board or the door lock. can be several different problems.
Nov 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I want to setup my Lucent AS40 answering machine
I had a problem recently when I looked online to find the manual for this model and a similar model, and thankfully I was able to solve the mystery and locate it. Even though the answering machine says it is a Lucent AS40, the correct user manual for it is the manual for the AT&T 1715. Once I figured this out, it was super easy to locate the manual on AT&T’s website... and sure enough, these two products are identical!!!
The user manual for the AS40 can be found at http://telephones.att.com/docMgt/public/art/161/1715_manual.pdf
I figured this out when I ran across an old article discussing a joint venture between Lucent Technologies (AT&T) and Philips Electronics. Apparently the two companies decided to merge together and combine their resources to develop technologically advanced answering machines. After the products were developed, each company marketed them under their name with a different model number, but both were selling the same thing! The reason we couldn’t find the user manual for the Philips model is because Lucent (AT&T) has the manuals!
In case this might help someone, I own two of these answering machines and can vouch that the user manual for the Lucent AS40 is the same as the AT&T 1715 and the Philips AD2735 is the same as the AT&T 1725. Here are the models that were produced during the joint venture:
AT&T/ Lucent 1715 = Lucent/ AT&T AS40
AT&T/ Lucent 1725 = Philips AD2735
AT&T/ Lucent 1717 = ?
AT&T/ Lucent 1815 = ?
AT&T/ Lucent 1825 = ?
AT&T/ Lucent 7625 = ?
AT&T/ Lucent 7630 = ?
Apr 09, 2009 | Lands Phones
I have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Mar 18, 2009 | Washing Machines
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Panel Beeping and F2 error code.
IT SOUNDS LIKE YOU GUYS HAVE A BAD KEYPAD/USER INTERFACE. LOOK IN THE SERVICE MANUAL FOR THIS TOPIC AND FOLLOW THE TEST:
ACTIVATION OF CONSOLE AND INDICATORS
DIAGNOSTIC TEST MODE
BOYNISMO@YAHOO.COM
Aug 05, 2008 | Kenmore Oasis HE 27087
Deleting Messages
system.
— Press
playing.
mailbox
number.
Jul 15, 2008 | AT&T 1725 Answering Machine
Victim of a brown out
I know this is a very old topic....
According to the 1715's manual, the "F" means that the memory is full. Try erasing some stored messages and see if that helps.
Here is the link to the 1715's User Manual
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=161
Dec 28, 2007 | AT&T 1725 Answering Machine
Lands Phones Logo
74 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
