SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
SOURCE: Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
SOURCE: whirlpool dishwasher
I can't guarantee to solve this but we had flashingh light problem and in the end all I did was to set the dial to the wash I wanted and kept my finger on the start button for about 10 to 20 seconds and it suddenly woke up and started. It had obviouosy had a hard day and wanted a rest
good luck
Martin
SOURCE: clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: Classique dishwasher, 3 weeks old.
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
