Question about LG Televison & Video
Tv is not displaying
When i try switch on the tv, the power fail to display, i mean is not working at all.
Your tvs power supply board probably has a blown capacitor. Just open up your tv and check that all the capacitostv is not displaying - 37d77cb9-7d6e-45ea-8be1-2a8ddfb09adc.jpg
As you can see in these photos the capacitor is blown or leaked.
Hope this helps
Posted on Dec 31, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
Hi I have found what goes wrong in this screen!
if you take it apart and email me i will send you a photo of the different things to look at for !
i have spare parts if any of your problems are not the same as mine!
ilovewhisky@gmail.com
Posted on Jun 11, 2010
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
Fujitsu li 2727 black screen on starting, power light on but wont display anything. tried hard reset and taken accesible hardware out and back in but still nothing.
Most laptops have a backlit display panel, usually a black screen means that the rear illumination has either failed or the switch which places the laptop into sleep mode when you close the lid has failed or jammed. Most sleep switches can be seen around the spine or hinges of the display panel and gentle coaxing with a wooden toothpick can usually release them but DO NOT use a probe made of metal as this could cause catastrophic damage if it touches and of the internal circuitry.
If you find that the sleep switch is working, take the laptop to a qualified repairer as laptops are really bad to disassemble and the display is NOT a repairable item. The inverter for the backlights is usually contained within the trim surrounding the display panel but may sometimes be hidden inside the base of the unit. THIS INVERTER OPERATES AT HIGH VOLTAGES. NEVER TOUCH IT OR ATTEMPT ANY KIND OF REPAIR WHILST THE INVERTER IS CONNECTED TO THE POWER SUPPLY - YOU HAVE BEEN WARNED.
May 11, 2011 | Computers & Internet
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
Camera says graph render fail what does this mean
Ok what that means is the DirectX "Graph" or set of instructions that tells windows graphics, how to perform, what Filters to use, and how to and what to, do with the signal to be displayed. This is generally an error to do with TV cards, Display cards etc. usually again, it means that the correct CODECs aren't installed, and when the "Graph" tries to "load" them, it cannot "Find" them, and thus fails, and displays that error message.
May 12, 2010 | Computers & Internet
What is standby mode and how to take off TV will not turn on
It means that something in the power section has failed,and the system goes into standby (safety) mode.Could be a fuse,resistor,or IC.Does it blink? On your remote you could press display,channel,5,volume - (minus),then power,for the diagnostics,.....for service mode press display,channel,5,volume + (plus) then power,press 8 then enter
Mar 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I can find nowhere on the tv that has an on off button, just got this tv
of the display.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
My tom tom has gone blank without warning.
Try these 3 things - wait at least 20 seconds before trying the next step:
* Reset the device, you may need to use a paper clip to do this, then try the power switch.
* Remove the SD card and re-insert it, then try the power switch
* Hold down the power button for about 5 seconds.
Jul 31, 2009 | Tomtom GPS
Monitor Display on TV
Try the following:
Power up the projector first. With the laptop hooked up but not powered on once projector is warming up begin booting laptop. If there is still no display once its projector is fully warmed up and laptop booted you can try using the (fn) key with the laptop monitor switching function key usually F4 which switches the display monitor to show on external, external and laptop or just laptop. If this all fails try changing resolution of laptop to something that might be more projector friendly.
Let me know how you go.
Mar 23, 2009 | Dell Inspiron 6000 Notebook
According to the Sony Service Manual for the PFM-500A3WU, 12 22 means either the Plasma Panel has failed or the Power Supply has failed. 12 means "warning decrease of panel high voltage" and 22 means "warning of decrease of middle panel voltage".ve had a look on other forums and someone as narrowed the 12/22 code down to the (ic102) its only outputing 5volts its something to do with the (b+ power supply)
Feb 01, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
