Question about Nikon D200 Digital Camera
PG UP error message
When i updated the firmware to 2.1 from nikon site ,the PGUP message shown on top lcd and the camera stop functioning but the FC led is green flashing
    Top Expert:
  • Nikon Master
  • 6,702 Answers
Did you change the USB settings in order to get the firmware on the memory card? if so, try to set it back.
If anything went wrong with the update process, like wrong memory card, touched a button while the update was running switched off or removed a cable. and and and. The camera can become damaged, or unusable. Nikon gives the advice to go to a Nikon service centre with the camera.
Posted on Dec 30, 2013
SOURCE: Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
Posted on Dec 11, 2008
SOURCE: "Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Posted on Feb 15, 2009
SOURCE: Nikon DSL D80 with "r02" error
normally, just removing the lens and putting it again you solve the problem. F-- problem means "there's no lens attached !"
Posted on Mar 17, 2009
  • 3 Answers
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Posted on Mar 30, 2009
SOURCE: Nikon D80 'error' and 'clock' message
La batería del reloj
El reloj de la cámara funciona con una fuente de alimentación independiente y recargable que se carga si lo necesita
cuando la batería principal está instalada o la cámara se alimenta mediante un Adaptador opcional de CA EH-
5. Dos días de recarga proporcionarán al reloj la energía suficiente para aproximadamente un mes. Si parpadea
en el panel de control, la batería del reloj está agotada y el reloj ha vuelto a la hora de inicio,
2006.01.01.00:00:00. Ajuste el reloj con la fecha y la hora correctas.
Posted on Nov 26, 2009
Is this a D80 or a D200?
If you had a failure during firmware upgrade, then your circuit board is trashed. Send it to Nikon - it requires software to replace.
Mar 18, 2013 | Nikon D80 Digital Camera
Nikon D80 shows PG UP during firmware update and stopped functioning
If you disrupted the camera during a firmware upgrade then you will have to send it to Nikon as it will require either replacement of the main circuit or complete reprogramming of the circuit with Nikon's proprietary software.
Jan 31, 2013 | Nikon D80 Digital Camera
My d80 showing" pg up" on controle pannel and camera not functioning
Did you get any solution for your problem? any update? I have the same issue with my D80.
Dec 21, 2012 | Nikon D80 Digital Camera with 18-135mm...
Software update in camera
There currently are no firmware updates available for the D60. Any firmware updates will be posted on the manufacturer's technical support web site at
Mar 25, 2010 | Nikon D60 Digital Camera
Nikon L100 shows battery exhausted error message after installing new batteries. Unable to perform any operations on camera
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Jan 24, 2010 | Nikon COOLPIX L100 Digital Camera
While my Nikon D80 is Error 09, can I update the firmware?
Have you e-mailed or called the techs at Nikon with your problem?
Jan 06, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error Message with Nilon D80
Have you been to the Nikon website to check for firmware updates?
Aug 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D200 Digital Camera Logo
260 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
