Check and see if there is a small pinhole on the back. Try inserting a paper clip. This would be a soft reset and has been known to clear up mirror imaging on some tablets. Also a swift hit on the back side of the tablet has been reported to work as well (try at your own risk) lastly try a hard reset but not you will lose you data. This option is found in the settings menu. Hope one of these works for you.
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
I had similar problem and I opened the back and disconnected the battery for 30 seconds, then reconnected it. Everything worked properly when I turned the tablet on.
Hello, Go to the manufacturer of the tablet and call their tech support. They will email you a file to download too your tablet to reload your software and correct your porblem.
If the tablet displays text backwards as if seeing it thru a mirror. This is an indication that there is a physical problem with the device and should be returned to where purchased if you are still in warranty for repair or replacement.
