Question about Samsung SyncMaster 931B 19" LCD Monitor
Monitor cold start issue only as #2 monitor
I have two systems and both use NVIDIA cards. The original system was an old Windows XP that used two Samsung SyncMaster 931B monitors on a Quadro NVS card. The system worked fine until one day after about 2 years the second monitor would not start automatically. It required many power on/off cycles and then would fire up. If power was just left on the screen would flicker every 2 seconds and then on the last flicker the screen would momentarily show and then go to black. The power indicator would show that the monitor was on. I assumed this was a cold solder joint or other hardware issue and since I was getting a new system I let it ride until I could retire it and have it repaired. When the new system was set up (Vista Ultimate 64bit) I moved the 931B that was the #1 on the old system to #2 on the new unit which is using a GeForce 9800GT card. From the first day this monitor which had worked fine in the old system as #1 now exhibits the exact same tendencies as the other monitor. When either system restarts from a short pause the monitors start without a problem. If the power is down for a couple of hours the monitor #2 does not recover and starts the 2 second flicker until the momentary full screen then goes to black but the power indicator stays on. Again, repeated power cycles would eventually allow the monitor to display properly. Once the display is on the montor works fine for all graphics. Since it happened on both systems I'm thinking this is a configuration/start command conflict problem. Do you agree? Any help or suggestions would be appreciated... Chuck
    Problem Solver:
  • 5 Answers
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
Posted on Jul 30, 2009
Monitor Compatibility with Vista
for your knowledge win xp or vista is not related to the moniter it will convert from its system compability so check out system configuration for vista and if it match with vista just load it and done.ok and if problem persist contact me
Dec 08, 2007 | Dell UltraSharp 1907FP 19" LCD Monitor
Screen flickering on windows 7 boot
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Nov 21, 2013 | Nvidia Computers & Internet
Windows Vista w/Samsung 19" monitor
Used to be CTRL and ALT and one of the directional arrows in xP (the numeric pad ones)
If you have a video card like Nvidia, and say Vista is the OS, try going to Control panel / Nvidia Control panel (or whatever your GFX card is) and the option to rotate is in there)
Jan 27, 2011 | Computers & Internet
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
Monitor doesnot pop out using nvidia graphics card
Am almost certain that this is a compatibility issue. Not all cards work with all motherboards. You should check this with the motherboard manafacturer in his website. That should help
Jun 16, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
New wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
Nov 25, 2008 | Computers & Internet
VX2025wm 20.1"
I have the same problem, mostly when the monitor is cold. I found a work-around tho. You bring up the menu, scroll through the options and select "memory". hit that it it does a memory reset, take about 3 seconds. After that, my monitor works perfectly. One time the power button stopped working and I had to unplug to turn the monitor off but it didn't do this for the last two days. Best of luck.
e
Jul 19, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
NVIDIA GeForce 6600
Did you try installing and updating the driver of the graphics card dedicated to the operating system "VISTA" ? Sometimes there is some difference between vista's driver and XP's driver.
Feb 02, 2007 | Nvidia GeForce 6600 Graphic Card
Samsung SyncMaster 931B 19" LCD Monitor Logo
226 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
