Question about Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil Filters 5
Yamaha rhino problem engine idles with no distress, dies when accelerated.
Hi people was running 1/2 to 2/3 speed when engine coughed & died. Engine now will crank up idle efficently but engine misses coughs & stalls when it is accelerated. Will not move from tracks. Changed brain & no change. Could it be a head gasket blown? Just a guess no proof. Thanks in advance for any help.
Idles fine,,push pedal and it dies
Idles FINE but stalls when pedal is pressed - Yamaha Rhino Forum ...
www.rhinoforums.net > ... > Technical > Engine
Feb 6, 2012 - 9 posts - ‎5 authors it starts fine but stalls when I press the gas pedal. what do I need to check now. Sponsored Links. RhinoForums.net is the premier Yamaha Rhino UTV/ATV Forum on the internet. Registered ... Does it seem to Idle smoothly and does it start right back up after it dies? Does it .... astro push accelerator and dies.
Oct 07, 2015 | ATVs
For my fz16 yamaha i wud like to ask what cud b the posible problem here is the symptoms.. when in cold start the engine runs fine but when it goes hoter the engine wont idle
Hi, Al-bar and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
http://fullmanuals.com/search/?q=Yamaha+FZ16
Sep 08, 2015 | Yamaha FZ 600 Motorcycles
Engine cranks up idles good won't accelerate
sounds like a restricted exhaust pipe ,remove the pipe from motor just to see if the motor power returns under throttle if so replace the pipe and gaskets
Dec 30, 2013 | Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil...
2007 yamaha virago 250 starts, idles ok, bogs at acceleration
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/18-engine-work/5238-engine-bogs-past-1-4-throttle.html
Bike idles perfect but dies when given the slightest amount of throttle 93...
Yamaha XV250 Services Manual
OEM parts for Yamaha
Yamaha VIRAGO XV250P Owner Manual
Nov 09, 2013 | 2007 Yamaha Virago 250
Car starts running rough at idle, eventually quits running. Has new plugs, wires, cap, fuel pump, fuel filter, air filter, IAC Valve, and gas cap.
Back then, Honda suggested timing belt replacement every 60,000 miles. If your Honda has that much mileage or more and has never had the belt replaced, now may be the time.
Sep 11, 2012 | 1995 Honda Accord
I have a 1985 Yamaha Virago 699cc.. It starts up and idles but dies when I give throttle?
Hi, Timothy and the usual suspects are:
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
http://viragotech.com/newtech/Only%20starts%20idles%20on%20choke%20dies%20when%20you%20give%20it%20gas%20(SOLVED).htm
Yamaha XJ700N Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 04, 2012 | 1985 Yamaha XJ 700 X Maxim
I have a 2005 softail, after riding for about a half hour, whenever i need to slow down or stop the bike will sputter, cough and die, if i feather the throttle to keep it going it still cuts out and dies...
Hi Kmeyer6595, and the usual suspects are:
2. Intake manifold air leak.
3. Loose low speed jet.
4. Contaminated or plugged low speed system.
5. Enrichner valve not seated or leaking.
6. Leaking accelerator pump.
Good luck and have nice day.
Jun 26, 2011 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
I have a 2004 60 hp yamaha 2 stroke outboard engine that doesn't start or run well. Once warm and in the water it will idle in nuetral and also in gear. It accelerates in neutral but will die or lack power...
Every sympton you are describing here can be attributed to fuel starvation due to blocked jets and or water in carbs, when your engine dies does it die with dry plugs, or wet oily ones?
Mar 25, 2011 | Sport & Outdoor - Others
My vstar 1100 dies when in idle. acceleration is fine. driving, shifting, everything else is fine. when the bike is coming down to idle, it dies
Is the idle speed set too low? If so, adjust it, using the idle speed adjusting screw, to the correct idle speed (900 RPM). If that's not the problem, then check for air leaks between the carburetors and the engine by spraying WD-40 around the intake manifolds with the engine running. If there is an intake leak, the engine RPM will change briefly when the WD-40 is sprayed near it.
Aside from that, there are two other things that can cause your engine to die when it should be idling: the idle speed mixture adjustment, or low cylinder compression. Of course, if it was idling fine before, and the idle mixture adjustment hasn't been changed, then do a compression check, first. To idle properly, each cylinder's compression needs to be at least 140 psi.
Nov 19, 2009 | 2004 Yamaha V Star 1100 Custom
1986 Chevrolet Celebrity - Surging Eratic Acceleration
Sounds like you have a vacuum leak somewhere causing the engine to flood.Check all hoses coming fron intake manifold.
May 10, 2009 | 1986 Chevrolet Chevy
Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil Filters 5 Logo
208 people viewed this question
Top Tusk Science & Laboratory Experts
William McMath
ray gallant
Are you a Tusk Science and Laboratory Expert? Answer questions, earn points and help others
