Iomega lphd160c When I connect it to my computer, it won't show up on "My Computer" and the hard drive starts makinging weird noises.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
Sounds like the drive is broken/damaged
You can try removing the drive from is case and connecting it direct to the computer. There are youtube clips to help you do this.
Posted on Jan 27, 2014
Bubbabear64
  • 2794 Answers
SOURCE: plugged in my iomega hard
Make sure you don't plug it into a USB hub. Some USB ports on computers can go bad from time to time. See if you can switch it.
If that doesn't work go to the control panel of your computer. Go to administrative tools. Go to computer management. Go to storage and select disk management. Make sure you see that partition for you hard drive. Format it to NTFS if you have to.
Posted on Aug 16, 2008
  • 34 Answers
SOURCE: WD Passport Hard Drive Malfunction
Unfortunately, you have probably lost all the files on the drive. It may be possible to take it to a PC Repair shop and have them run specialist software on it, although the clicking sound indicates a hardware failure, rather than software. You have my deepest apologies, but this does happen... although rarely.
Posted on Feb 03, 2009
Crankstart
  • 696 Answers
SOURCE: My Iomega Portable Hard Drive will not boot up
Hi Jim,
This may be a boot order issue. Can you boot the drive when it is unplugged?
Then, if you can, does it work if you plug it in after windows is up and running?
If the answer to both is yes, then you need to enter your BIOS/Setup as the computer first starts, with the Iomega drive plugged in and select your hard drive as the first boot device.
If you can provide us with more detail, we can give you the specific steps. Either way, comment back and either tell us it work or tells us more about your computer... Make & Model, and we'll do our best to walk you through it.
Chris
Posted on Jul 18, 2009
irfan6200irf
  • 147 Answers
SOURCE: I have a problem with my iomega lphd160c
if u have a installer cd with the device then
please install the driver
Posted on Dec 25, 2009
SOURCE: PC not recognising Iomega Prestige 320gb usb portable hard drive
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Posted on Mar 08, 2010
My wife and I bought an Apple mac computer just over 3 years ago, and as we wanted to store our large collection of CDs on i-Tunes on an external hard-drive and not on the Mac computer drive, we bought an...
no --there are no engineers at fixya site
from your description the aux hard drive has failed
Most hard drives using discs are good for around 3 years max and then the bushes and bearings fail
If that is the case then you will have to find a repair shop that has the capability to remove the disc from the hard drive and recover all that you have saved
if it as what I have suggested then consider this
There are hard drives (SSHD) on the market that use solid state technology and do not have spinning discs that fail over time
The cost is around $60.00 per gig of storage
best if you take it to a computer repair shop for a proper diagnosis and while there discuss the SSHD technology to prevent failures in future
Feb 27, 2017 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
My Iomega hard drive isn't working whenever I plug it in to my computer I hear a clicking noise but no response, meaning my computer or others are not reading it.
noise coming from a hard means that the hard drive is already have a problem and if it is not read by the computer it is already broken you must replace it.
Aug 01, 2011 | Iomega Computers & Internet
My iomega hard drive worked fine before, but now won't show on My Computer or Autoplay. Help, please?!
First check whether your computer can see the external drive:
1. Right click My Computer and select Properties
2. Click on Device Manager
3. Expand Disk Drives by clicking the arrow on the left side of it.
Is the IOmega in the list of the disk drives?
If it is, then it is either:
1. The drive is faulty and the ID is from the IOmega controller
2. The drive is ok but severe bad sectors or other failing components prevent the drive to mount.
Testing the External Drive.
Listen closely to the if it sounds like it's spinning or it's doing something.
1. Clicking sound - The hard drive inside the Iomega caddy is faulty, either the pcb or heads, or both
2. Scraping sound - There is a platter damage on the drive. Recovery not possible.
3. No sound at all - Problem with either drive's pcb or the Iomega controller.
If your drive behaves like one above, I suggest you send your hard drive to data recovery companies.
May 06, 2011 | Iomega Professional 500 GB FireWire 400...
I have a iomega eGo 500GB which I used on a dell laptop running Windows XP. I backed up all my files on the drive and now have a new laptop running Vista (old laptop has gone) put whan I pluged in the...
Enable "File and Print Sharing" on the "old" computer.
Connect the IOMEGA to the "old" computer.
Enable file-sharing on the "root" folder of the IOMEGA.
Connect the "old" computer to one of the LAN ports on a router (wired or wireless).
Connect the "new" computer to another LAN port on the same router.
Make sure that both computers are in the same "workgroup".
From the "new" computer, browse to "show computers in my workgroup".
You should see an icon for the "old" computer.
Double-click that icon to "open" that icon, and you should see all the files on the IOMEGA.
Copy those files to the 'C:' drive on the new computer.
Nov 11, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
I can't access my iomega 1TB desktop hard drive, it tells me to insert a removable disk when ever i click on it from My Computer
Hi.
Test the IOmega using a different computer. If it does the same the SATA connector to the hard drive, inside the closure may have slipped off.
If problem is computer, power off and disconnect power cord for ten minutes. If the computer is a laptop also remove main battery.
Disconnect hard disk, and connect everuthing back.
This will fix some USB related problem.
If that does not fi the problem, a system restore to a date before problem started may help.
Jun 13, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Dec 25, 2009 | Computers & Internet
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
