Question about Philips 60PP9352 60" Rear Projection Television
Burnt resistors I have 2 burnt resistors on my board but cannot locate a schematic. I cannot read the color code off of resistors 3156 and 3164.
Resistor 3156 is SSM CBA to ground from Conv power packs 7045. replace both convergance power packs gen part # stk392-120 res 3164 is 100 ohm OK.
Posted on Oct 24, 2007
    Genius:
  • 1,694 Answers
Researching resistors---
What caused the resistors to burn?? Have you already fixed
that? If so, what exactly was it ???   let me know...T.
Posted on Oct 22, 2007
  • Vista Electronics Oct 23, 2007
    Location 3156  is 6.8 ohm 1 watt
    Location 3164 is 3 watt part # 212010593449. Hope that helps, I
    couldn't get value of 3164.......T
What is the value of R617
In order to answer that, one would need to know the manufacturer's name and model number to the CRT you're trying to repair- in order to look up the schematic for that particular unit...and the printed circuit board number that the resistor 617 is positioned on...
Try an online search engine to locate the service/repair manual for your t.v, or go to a local t.v. / electronics repair shop; they'll be able to ID the resistor you'll need.
Apr 08, 2015 | Televison & Video
Can anyone provide a location where is can find a schematic for the HVAC control dash unit out of a 2005 Buick Park Avene?
There won't be a schematic available for what your asking. Only electrical schematics that show wiring harness (to and from) the A/C controller. So what I suggest you do is go to a "Pick Your Part" type wrecking yard and get a replacement controller from a simalar Buick or Chevorlet model. Should be a couple different models built in '05 that use the same controller
Apr 10, 2014 | 2005 Buick Park Avenue
Maytag MDB7100AWB dishwasher board burnt resister
first of all they wont give you any specs on circuit boards for most appliances,they just want you to replace the board besides that,if a resistor burnt its because there was a heavy current draw on another component that is supplied by this resistor and you would need to locate this defective part such as a motor/solenoid/heater or the new resistor will end up in the same manner,the 2 oozing parts are probably capacitors leaking their die-electric compound from heat and age so they are in need of replacement too,you might go online and ask somebody with a board like yours for the part values,but still you need to find the main problem for the problem on the board first
Aug 12, 2012 | Maytag MDB7100AWB Dishwasher
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
How do I find the value of a resistor if it is burnt?
sometimes the component is listed on the circuit board in it's value where it is mounted.
can you read the color bands? if not than a schematic will list it.
Sep 20, 2009 | Televison & Video
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Aug 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
120 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
