Question about Tools & Hardware - Others
Manual for black diamond pnt 138 brad nailer
I need a manual where can I get one
4 Suggested Answers
rcalorisian
  • 313 Answers
SOURCE: magazine cover for airy nailer
Airy no longer has a home base in the USA. E-bey might be your best option
Posted on Sep 08, 2009
  • 15 Answers
SOURCE: how to remove brads jammed in the nailer
Open the top where the plunger is...remove the jam and push the plunger back..close up the gun and you should be fine. Make sure you disconnect your air hose first!!!
Posted on Jun 08, 2010
SOURCE: my black and decker 18v brad nailer will not shoot brad
I had a 12v b&d brad nailer that stopped working.It would just blink & blink (red light on tool). I took it to b&d service center, and I was sent a new 18v nailer. Now I've had this nailer less than a year, I
believe this is the 2nd or 3rd time I use it. It's doing the same thing
as the 12v. I just use it around the house. The batteries are good.
I 've also had the charger go bad and the batteries. which have also
gone bad.
Posted on Jul 11, 2010
NT50AE2 Hitachi brad nailer depth adjustment
Go back to the dealer and ask for help if its a problem with the receipt is always within 8 days Exchange possibility if something does not normally functioned.
This must not be a problem.
Jun 18, 2016 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
My Task Force electric brad nailer is jammed.
Brad nailers typically jam for one of two reasons, a misaligned or bent brad on the brad strip or a defect in the brad strip itself. Remove the brad strip in the nailer and replace with a new one. Examine the striker head first for any signs of residue keft from the jammed strip.
Oct 31, 2010 | Garden
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
My black and decker 18v brad nailer will not shoot brad
look to see that you are shooting the right sized nails in it. 16 and 18 gauge nails dont interchange and the can get hung up under the plunger if the try to shoot at all
Dec 15, 2009 | Tools & Hardware - Others
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Brad nailer does not retract enough for brads to enter nailer
hi check to see if there is any wear on the blade or even if it is broken if so replace with a new item from your dealer , this will also come with a new seal so with a good clean your gun should bee like new hope this helps ian
Mar 24, 2009 | Black & Decker Air Tools & Compressors
Tools & Hardware - Others Logo
198 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
