Question about Chevrolet Silverado 1500 80-1858 Smartcable
Fuel problems or carb
When in park can rev eng to high rpm with no problem ,but when driving and stomp on it bogs down and almost cuts off till i let off gas then it idles ok .it has new mechical fuel pump in it ? so is it fuel problems or whay .
    Sergeant:
    Champion:
  • 338 Answers
Sounds like you have a partial colapsed fuel filter--change and retry
Posted on Dec 31, 2013
Saw starts but after it warms up it revs uncontrollably at high rpm's, wondering if the seals or rings may e gone?
Seals and or rings would not make the saw rev high. More likely the throttle is sticking open after it gets hot. Check throttle position and clean. Get a can of spray carb cleaner from auto parts or the marine store. Spray away till it's clean and check the throttle position again. RPM's only go up for two reasons, and they are both fuel air ratio. One is the throttle is open the other is momentary rev when the fuel supply is cut off.
May 26, 2015 | Echo CS400 18" Chain Saw
Bogs down at high rpm
check for fuel flow from the tank . check for blocked fuel filter. check that the choke butterfly is not being allowed to close at high air flow causing the engine to flood.
May 05, 2013 | 2003 Triumph Bonneville America
Hello, i have a stihl ts400 and i just rebuilt the topend(crank,piston,cyl,all bearings and seals.Fires up easy, idles fine,revs fine, but when you hold the throttle down it doesent want to hit rev limiter...
There is not an actual rev limiter. The top end is controlled by the carb. You actually want it to sound a bit rich at full throttle so that it has enough fuel when cutting under a load. What causes me some alarm is the revving up part. If it revs too fast that is a lean condition and can quickly ruin the piston and cylinder much like running straight gas. A torn intake boot can cause this. The high speed spec for the TS400 is 9,600 rpm + OR - 500 RPM. Your saw may not have a needle to adjust the high side as some have only the low speed adjuster. Also when you disassemble and clean the carb always use a new kit with the gaskets and diaphragm. Any Stihl dealer can furnish the kits and they aren't terribly expensive. Often between $10-20.
Jun 26, 2012 | Saws
98 saturn 1.9 eng bogs up n down at 4000 rpm
just wondering is your car doing this in park saturns have a rev limiter that will not let your engine rev past 4 k if the car is in nutreal or park
Mar 26, 2012 | Cars & Trucks
My grang cherokee2002 us spec, while driving trnz changes fine but when cick down or full excelrate and RPM reaches 4.5 or 5 engine is loosing power and getting noisy and RPM not going more, while gear on...
You are hitting the rev limiter top range, which cuts off your ignition.
I have a 2001 Grand Cherokee and the problem drives me crazy, but it is the way the car is designed- as soon as you hit the rev limit, it shuts down ignition and your jeep will "buck" - a real pain when you are trying to accelerate into traffic!
You have the 4.0L straight six engine, yes?
If so, please take my advice and learn to live with the minor annoyance of the rev limiter- that engine is IMHO the best Chrysler ever made (nearly "bulletproof"!) and it was so reliable you cannot even get it in a jeep now! For decades, that engine was used in welders, tractors, generators...and yes, jeeps... and it is a favorite among mechanics for its durability!
Feb 01, 2011 | 2002 Jeep Grand Cherokee
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Intermittent fuel starvation,high rpm at idle restart eng all ok
You should verify you have proper fuel pressure. Check with a gauge when cold and hot. Possible clogged fuel filter is not allowing enough gas to feed engine. Verify pressure at idle and also under load when driving.
Dec 06, 2009 | 1986 Ford Aerostar
Chevrolet Silverado 1500 80-1858 Smartcable Logo
52 people viewed this question
Top Metra Vehicle Parts & Accessories Experts
Tom
Jim Y
Jim Y
john h
Are you a Metra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
