Question about Chevrolet 2005-2012 Malibu Steering Wheel Cover Euro-Perf 2 Color, Size C
Cylinder misfire p0300
What would make my car do this
    Top Expert:
  • 12,104 Answers
A misfire can be anything from fouled plug ,ignition coil going bad to bad gas more than likely your in need of a tune up
Posted on Dec 31, 2013
Has p0300 code misfire cyl 2 and 3
If it was just cylinder 2 or 3, the code would be 0302 or 0303. Instead, you have random misfires (probably) such that you should be checking things that affect the whole engine. Vacuum leaks, bad plug wires, bad coil(s) or ignition module are most likely, but even clogged exhaust, O2 sensors and bad battery can cause these problems. Yes, a battery can be good enough to start your car but still be bad enough to affect performance. If I had to guess, I would start by testing the ignition module. Most parts stores can test this if you remove it and carry it to them.
May 04, 2015 | 1998 Chevrolet Blazer
Why won't my car start?
P0300 multiple misfire
P0302 misfire cylinder 2
P0306 misfire cylinder 6
Apr 25, 2015 | Cars & Trucks
Codes P0300 P0302 P0303 P0304 P1176 P0133 P1300 P1580 P1543 B0423is running but having trouble building speed and going up hills
Codes p0300 random misfire, p0302-0304 misfire cylinder 2-4. P0133 o2 circuit slow response bank 1 sensor 1. P1176, P1300, P1580, P1543, B0423 r make specific which you didn't say this would cause the problems you are having.
Apr 07, 2015 | Cars & Trucks
P0300
P0300 = radom misfire
could be any cylinder
monitor engine misfire screen and see which cylinder is misfirering
Jan 28, 2014 | 2004 Cadillac CTS
Me aparecio el problema p0300, p0301, p0302 y p0600
p0300 random multiple cylinder misfire, 301 is cylinder 1 misfire and 302 is cylinder 2 misfire. p0600 is a communication link fault.
Sep 19, 2012 | 2000 Kia Sportage
P0300
Im assuming your asking about the ODB-II codes, this code,P0300 Random/Multiple Cylinder Misfire Detected.
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Here are a few things that could be the cause.
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • Defective computer
    I would start things out with a tune up, new plugs and wires, wires break down after time and could be grounding out, or arcing between themselves causing a misfire.
  • Jul 05, 2012 | Cars & Trucks
    When my car is ran on computer is has cose PO300 PD. What does this indicate?
    DTC P0300 - Random/Multiple Cylinder Misfire Detected
    Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
    Hope this helps.
    Oct 03, 2011 | 2004 Chevrolet Malibu
    Obd codes p0300 p0301 p0303 p0305 p0401
    P0401 Exhaust Gas Recirculation Insufficient Flow Detected
    P0301 Cylinder 1 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    I would check out the EGR valve. That maybe what is causing all the misfires.
    Mar 24, 2009 | 1997 Toyota Camry
    I am workiing on a 1999 toyota carolla has a misfire
    Here is a good site for OBD II trouble codes.  P0300: Random/Multiple Cylinder Misfires Detected, P0301: Cylinder 1 Misfire Detected, P0304: Cylinder 4 Misfire Detected.
    Jan 25, 2009 | 1999 Toyota Camry
    Chevrolet 2005-2012 Malibu Steering Wheel Cover Euro-Perf 2 Color, Size C Logo
    Top Wheelskins Vehicle Parts & Accessories Experts
    thunderalley
    thunderalley
    David Harrelson
    David Harrelson
    RAYMONDO1953
    Are you a Wheelskins Vehicle Part and Accessory Expert? Answer questions, earn points and help others
