Question about Toshiba TEC B-472 Thermal Label Printer
TEC B-742 slowly - Toshiba TEC B-472 Thermal Label Printer
Tip
Dish Network Stereo Receiver Remote Codes
This is the From the Dish Network website. http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml You can also call them for information on your set-up at : New customers call: 1.888.825.2557. Current customers call: 1-888-686-2388. CODE Aiwa Amplifiers 636, 641, 656, 687, 718, 720, 774, 775, 726 Bose Amplifiers 761 Carver Amplifiers 653 Citizen Amplifiers 709 Curtis Mathes Amplifiers 734 Denon Amplifiers 647, 674, 757, 758, 759, 760, 762 Fisher Amplifiers 653, 741 GE Amplifiers 711 Goldstar Amplifiers 677, 69 Harmon / Kardon Amplifiers 640, 672, 751 Hitachi Amplifiers 717, 754 JBL Amplifiers 640 JVC Amplifiers 637, 683, 703, 725 Kenwood Amplifiers 649, 676, 691, 726, 728, 745 Luxman Amplifiers 752 Magnavox Amplifiers 654, 705, 740 Marantz Amplifiers 651, 740, 742, 743, 764 NAD Amplifiers 739 Nakamichi Amplifiers 671, 748, 750 NEC Amplifiers 716, 739 Onkyo Amplifiers 642, 660, 662, 678 Optimus Amplifiers 648, 664, 734, 744, 749 Panasonic Amplifiers 643, 644, 652, 742, 746 Pioneer Amplifiers 658, 667, 668, 679, 702, 734 Proton Amplifiers 654, 705 Quasar Amplifiers 652, 742, 746 Radio Shack Amplifiers 744 RCA Amplifiers 635, 638, 704, 727 Sansui Amplifiers 753 Sanyo Amplifiers 741 Sharp Amplifiers 712, 713, 714, 715, 749 Sherwood Amplifiers 646, 670, 736, 738, 744 Sony Amplifiers 639, 645, 650, 687, 728, 728, 730 Soundmatters Amplifiers 763 Teac Amplifiers 684, 737 Technics Amplifiers 643, 644, 652, 742, 746 Toshiba Amplifiers 710 Yamaha Amplifiers 663, 730, 731, 732, 733, 745, 747
on Jun 06, 2009 | Toshiba XB1507 Receiver
I own a Remington 742 rifle , serial " 229608 . I want to know the facts or history of this gun .
Ricky, here is a link to the history of the Remington 742:
http://www.remingtonsociety.com/rsa/journals/Model_74N
This paragraph has the most pertinent information:
"The Model 742 serial number sequence was changed on November 26, 1968 as a result of the 1968 Gun Control Act that required no two guns from the same manufacturer have the same serial number. The initial Model 742 serial number sequence began at 1001 and ended at 396562. The new serial number sequence, now shared with the Model 760 pump-action rifle, began at 6900000"
Dec 26, 2014 | Optics
Lighter trigger pull on Remington model 742
NO! That is already an insecure system that is unsafe as made. ANY alteration of the hammer and sear makes it ever more so.
Nov 02, 2014 | Remington 700 Model 7 742 760 7400 7600...
After market trigger for Rem 742
You can try this spring from erniethegunsmith:
http://erniethegunsmith.com/catalog/i36.html
Or the 870 Trigger Fix from Timney:
http://www.brownells.com/.aspx/pid=32078/Product/REM-870-1100-11-87-TRIGGER-FIX
The 742 is an old gun. Not much made for it now.
Jul 06, 2012 | Car Audio & Video
TEC Sterling II, Pilot light not lighting ceramic burners. Got new ignitor. It does create a spark but it doesn't jump to the pilot light or to the burners.
The gas may not be reaching the burners. Try match lighting a burner to see if it is. If it isn't do the following.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. If you're using as 1 Lb
Canister tank. Turn the valve off and remove the canister.
2. Wait 5 minutes and reconnect the hose to the tank. Reinsert the canister.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. Or you will have to replace the Canister Assembly. For that you'll have to go to Tec Grills. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 08, 2011 | Tec Sterling II Grill
Mc culloch chain saw 742 manual need urgently
Both the OM and IPL can be found here:
http://www.mcculloch.biz/int/support/owners-manuals/
Just type "742" in the "Model Search" window and click Search. HTH
Lou
Feb 17, 2010 | McCulloch Garden
Toshiba TEC B-472 Thermal Label Printer Logo
42 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
