Question about Epson Stylus CX6000 All-In-One InkJet Printer
No power to printer
I have an Epson DX 6000, I cannot get it to power up,is there an internal fuse that may have blown ora re-set switch somewhere ? Thanks in advance. Pat
  • patman207 May 19, 2009
    Hi Joe,
    It seems that the cord is O.K.I have had it tested.
    I'm not sure how to proceed further to remedy the problem.
    Pat
    Scholar:
  • 93 Answers
Hi Pat,
Most printers do not have an internal fuse. Most of the times its the transformer in the power cord and that must be replaced. Assuming it did not get wet and that it did not get a voltage spike from a storm it may have just overheated. If it has a special connector on it such as a three prong when going into the printer it is sometimes cheaper to replace the printer then the cord itself.
Posted on May 19, 2009
I have a 2006 Dodge Caravan and the heat, radio and wipers quit working, as well as power windows? Replaced battery and replaced a big bwd fuse, alternator? What may be causing this and is it common in...
Their is a problem somewhere and answer is the blown fuse in the power distribution box under the bonnet ,so no doubt its blown the fuse again and the answer is to find out why ,if it hasnt blown the fuse again then their is a break in the power cable to where it goes to next which is the internal fuse box so check the cable froim the big fuse to the internal fuse board for damage .
Feb 22, 2013 | Cars & Trucks
No brake lights
Either
the bulbs have blown or
the lamp outage module has blown if it has one (some did some didn't for this year) or
a fuse or relay has blown, or
the most likely culprit is a faulty brake light switch -- you will find this attached to your brake pedal
Sep 13, 2012 | 1996 Isuzu Rodeo
I have a Nuvo Grand Concerto System (NV-18GM) that I am setting up. I initially plugged it in to 240V mains power before realising I had to reconfigure a couple of internal wires (switching from the...
If the main amp section does not have it's own fuses, then the fuse might have blown, because the amp has gone. However I think it is highly likely that you have taken out the main amp, especially if it is a single IC that does all the work. You should try and determine if the amp section is getting power before replacing it.
Mar 19, 2017 | Audio Players & Recorders
My Epson D92 has virtually blown up. I have had it for quite a while now so it is probably better to replace it. Could you recommend a reasonably priced replacement which uses E-T0711/2/3/4 cartridges. ...
all the SX115 to the sx 600FW and th DX 4000 - DX 9400 range take these ink Carts. also the BX600FW and BX610FW the BF are Faxes all in one too. hope that help/
Oct 01, 2010 | Epson Office Equipment & Supplies
The power blew while it was on with the dryer
check the hv capacitor for a short and fuse, if thats not the problem call electrician, sounds like a bad breaker
Feb 04, 2010 | Magic Chef CMV1000B Microwave Oven
Epson dx6000 no power is there an internal fuse?
epson dx 6000, lost power checked mains fuse ok, is there an internal fuse?
Sep 22, 2009 | Office Equipment & Supplies
Epson 5300 not powering up
Did you fix this problem? If so, please let me know as I have the same problem.
thanks
Jun 29, 2009 | Epson 5300 7200 7300 Replacement Lamp -...
No power
You have an internal problem...show it to electricial...or go for the warranty........
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
May 09, 2008 | Epson Stylus D88 InkJet Photo Printer
F70
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Jan 14, 2008 | Technics SA-DX850 Receiver
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
221 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
