Question about Roper Dryers
Roper model red4440vq1 runs only a couple of minutes on high heat setting
Dryer will only run a couple of minutes on high setting and shuts off have to wait a bit before you can restart runs ok on low heat setting
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
  • 63 Answers
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Posted on Mar 13, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
The dry wont run on high heat cycle but will run on the low heat cycle
Could be the Hi Limit Thermostat causing problems. There are over 350 Roper Dryers. Not much can be diagnosed without knowing the actual model number of your dryer. Please drop a comment with full model number. You can view the parts by selecting the correct model from this site.
RoperDryer Parts
Sep 02, 2014 | Roper Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Roper RED4440VQ1 how do you know if high limit thermostat is broken?
you have to unplug the dryer,and remove at least one of the wires and read it out with a meter to check it for continuity.you can go here and see the parts you need to check,http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Dryer-Parts/Model-RED4440VQ1/0893/0151200/W0905172/00003?blt=06&prst=0&shdMod=RED4440VQ1
check the element,part number 17 on the diagram and is part 279838,if that's good check the thermostats on the heater box, part 9 and 15 on diagram,if one of them is bad buy part number 279816,it replaces both of them,also check the thermal fuse number 7 on the diagram and it's part 3392519.your lint filter is on top so all your parts are in the back,pull out the dryer,unplug it,remove the vent line and then the back panel,also take out the lint filter and the two phillips screws that are on the top panel and in front of the lint filter,when you're in the back,remove the 4 screws and clean out the metal duct that the filter slides into,if the vent line is a long run you can blow it out with a leaf blower,make sure nothing is blocking the air flow outside,if there's a cage or screen remove it so the lint doesn't build up and block the air flow.hope this helps and good luck.
Dec 19, 2012 | Whirlpool LER4634J Electric Dryer
No heat/Only works on one setting
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 08, 2012 | Roper Dryers
I have a Roper Dryer mod# Red4440VQ1 ser# my3678178 My prob is the dyer will not start unless it is in no heat mode. I think it's the timer Robert
sounds like the safty is keeping the unit from working check dryer vent for lint from outside to back of unit
Aug 27, 2011 | Roper Dryers
I have a roper dryer model red4440vq1 and it want start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 29, 2011 | Roper Dryers
My red4440vq1 does nothing
heatman101
Mar 15, 2011 | Roper REX4634KQ Electric Dryer
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
27 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
