Question about Lands Phones
Bt graphite 1500 phone no dial tone
Bt graphite 1500 cordless phone and answer phone,base unit for phone 1 and answer phone plus 2 other phones with chargers. all functions work on all three phones and ok on internal calls from/to phones 1 2 and three but no dial tone out and wont ring or receive in coming calls. brand new phone set. line ok and checked. old phone works fine on this line. have tried turning off at power in then on again.but no change.
4 Suggested Answers
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
consultel1
  • 860 Answers
SOURCE: samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Posted on Mar 21, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
Why can't I use it?
do you get a dial tone when trying to make a call . it has to be plugged into a phone jack and an electrical outlet
Dec 04, 2015 | BT Studio Plus 4500 Cordless Phone - DECT...
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
No dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Both phones are flashing base 1 with no ring tone on a bt studio 1500
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Jul 14, 2008 | Lands Phones
Bt quratet 1100 no dial tone
Sounds like the phones have not been registered to the base unit. Look in the manual for directions on how to get the phones and the base unit to talk to each other. Sorry, I don't have any details on theis model to look up the instructions.
Jul 23, 2007 | GE 25831GE3 Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
